View Full Version : LeSabre
Pages :
1 2 3 4 5 6 7 [ 8]
9 10 11 12 13 14 15 16 17 18
- Need help with a seatbelt problem!
- UIM Lawsuit
- Removing sparkplugs
- Where to Buy a Fuel Gauge Sending Unit?
- Need Help finding wool seat covers
- Cost of replacing passkey
- Flippin' rear VC!!!
- Electric Trunk Release Device Problem
- Spoiling my Ride
- Brake/Blinker problems PLEASE ASSIST. 2004 buik lesabre
- How to remove back seat?
- 1993 Fuel Filter
- 1993 LeSabre Seat Swap?
- 98 Custom, Chip in key going bad?
- 2001 Lesabre Rear Brake Noise
- Broke Turn Signal on 98 Custom
- 2000 Buick LeSabre Intermittent start, strange behavior! PLS HELP!
- 1995 Buick Lesabre Limited
- 92 Buick Lesabre Limited. wireless remote control
- 1992 LeSabre Custom Temperature Sending Unit
- How to Troubleshoot Cruise Control on a 1997
- Subwoofer and amplifier installation
- 94 Buick Le'Sabre 3800 engine won't start
- 97 Lesabre dies, will not restart, but will restart later. No codes
- Need to Rehab a 1990 LeSabre Custom
- Full Metal Body
- UIM/LIM assembly
- 2000 Buick whining noise at high speed
- 97 Lesabre(limited) climate controller problem
- 1995 Lesabre Key/Security light help
- UIM Kit Comparison? GM, APN, Dorman
- Problem with the gas gauge
- 1997 Buick Lesabre- Please help
- One more question
- Help...I cant get my wipers off.
- Power Window Motor Issues 1990 Buick LeSabre Custom
- 97 Lesabre whistle /squeal driving me crazy
- 98 LeSabre engine
- HB removal tool for 94 Lesabre 3.8
- OBD question 95 Lesabre
- 98 LeSabre engine code question
- Help, 97 Buick LaSabre water pump replace...
- '89 Lesabre Oil Temp Light
- 93 LeSabre Front End Scraping
- 1996 LeSabre misses on acceleration
- 1995 LeSabre Custom Unpredictably Shuts Off While Driving
- Question on Traction Light
- Can anyone comment on "Bendix" brand brake pads?
- power windows / power lock issues-- 90 buick lesabre custom
- FRUSTRATED: blower motor resistor location 98 LeSabre
- Type of Gas & door speakers on 94 lesabre
- 1994 Buick Leasbre chuggs when accelerating when hot outside
- 94 Lesabre - Loses fuel when hot, pump wont charge nor engine fire. Please Help!!
- Installing After Market Tack In 1990
- Quit running while hot
- 92 Buick Air temperature is blinking and blower is not working
- Source for 2001 LeSabre carpet?
- 2001 lesabre:shuts down
- 94 buick lesaber custom
- 95 lesabre oil leak?
- Crazy Horn Problem - Listen To This Story & Need Advice Please
- What all can cause a car not to crank? 1997
- ABS problem,94 lesabre
- 94 buick harmonic balncer issues
- DTC P0442
- 92' Lesabre a/c flows thru defrost vents only
- 91 LeSabre Delco Radio
- Ignition module Green Goo
- Replaced 94 Lesabre Brake Rotors and Calipers
- climate control issuse
- break light and break light chime
- 94 lesabre starts, immediately stops
- How to replace rear struts on 95 LeSabre???
- ignition key gets stuck
- 95 Buick LeSabre A/C Clutch Replacement
- '93 Buick Lesaber No start, Not Battery. Please help.
- Low fuel light in '93 w/ indicator lights?
- Buick LeSabre Wont Start In Hot Weather
- Door Panels
- 93 lesabre fuel pump and filter help
- 1992 buick lesabre electical
- 92 Lesabre stalls after 10 minutes
- need some expert help here- Violent shaking / pounding from engine compartment
- Hood Removal
- Can speed wreck cruise control?
- 95 Buick Lesabre error codes
- 1998 LeSabre driver tail light keeps burning out.
- 92 LeSabre stalling, erratic idle
- 97 Lesabre ABS Light On and No ABS
- Air in Rear Brakes
- Power Windows revisited
- '89 Le Sabre - Check Engine light-stalling
- 98 buick 3.8L seriesll
- What is an Adaptive lamp monitor?
- Front Brakes Problem!.. Streering Wheel
- Lesabre Front Bumper
- 97 LeSabre EGR problem
- Odometer Reading
- Hubcap/wheel cover locks
- cooling fan
- Lesabre keeps stalling out...FRUSTRATED
- 2000 LeSabre Service Manual
- Rear turnsignals not working
- 2005 LeSabre Transmission chatters slightly when shifting from 1st to2nd
- what transmissions will mate with and 80's 3.8l v6?
- 92 Lesabre part changed , code and problem still there
- 92 lesabre rear brakes
- 95 LeSabre oil leak
- "Tune-up" or maintenance questions
- What years (if any) LeSabres got the L27 Series III?
- fuel pump issues
- A/C problem
- 93 Lesabre Stalling and no one knows why
- A/C Clutch
- 95 paint code
- 1994 Lesabre Steering Column
- Tail Light Bulb Mystery - Wow!
- Rear Windows De-childproofing
- 95 Buick LeSabre Power Lock Problem
- 94 lesabre tranny
- 87 lesabre problems....need ideas
- 97 only starts on the second try
- ODC II code P-0113 IAT sensor
- Oil Pressure Sender
- 95 LeSabre Hesitates During Heavy Acceleration
- Beware: Cooling System Leak On 1995 LeSabre (3.8)
- Rounding torx bolt on motor mount
- 94 LeSabre SES COdes
- Car just shuts off
- ABS , tracktion off lights are on after i start the car
- leather top
- 1989 LeSabre Intake Manifold Coolant Leak
- May buy 97 LeSabre: will they go 150k to 250k miles?
- 2000 LeSabre Dual Climate Control
- Changing struts on 98 LeSabre
- IAC/TPS Adustment '89 3800 Series
- How difficult is to replace Camshaft Position Sensor
- 91 lasebre idling poorly
- accessing rear door handle in 2000 lesabre
- remote entry doesnt work and a few other problems
- outside rear door handle
- Swapping a L26 Aluminum Intake Onto The L36 Engine
- I let my stupid sister drive my car!
- Engine code #17 and #24
- power steering pump 1998 la sabre
- interchangable parts
- tranny swap
- Full Size LeSabre Estate Wagon Downshifting Wrong
- 2000 Lesabre Noise in Rear
- AC crapped out-1999 lesabre
- 91' Lesabre stalling when coming to a stop/pushing brake pedal
- power door locks
- Diagnostic Questions
- Power Antenna Plug
- Help with car hesitating on idle.....
- 97 Buick Stalling
- Do you live in Raleigh, NC and know of a good place to diagnose A/C
- 1993 Radio Wiring Diagram
- 96 LeSabre AC Losing Vaccume - Electric?
- Fixed my stalling problem 97 Buick Lesabre
- 1995 LeSabre Insurance Total Loss Advice Needed
- How to remove rear trans mount on 92 Lesabre?
- 97 lesabre A/C compressor noise
- Fuse Box
- What is that big black box under the cowling on the passenger side??
- 2000 Dash pad problem
- '93 Lock-up torque converter problem
- 1995 Buick LeSabre Paint Peeling
- A/C blowing fog and won't defrost windows
- heater problems
- Wet Carpet
- Readdy to do my upper intake, few questions
- 88 LeSabre stalling
- '93 Tranny Swap
- 95 lesabre a/c comes on with heat
- where is the fuel filter fuse 97 Buick lesabre
- Engine Coolant Sensor Location ??
- 1992 LeSabre condenser
- 1995 Buick Lesabre A/C Problem
- 95 lesabre quit, won't start
- 2000 LeSabre blower fan location
- fuel pump?
- 88 lesabre cranks but don't start
- 94 Master Cylinder Questions
- 99 LeSabre Heater Fan
- cofused
- 97 Buick Lesabre speedometer works occasioinally.
- A helpful link about engine vacuum
- 1995 buick lasabre fuel problems
- 94 Buick Lesabre stalling
- '94 Buick LeSabre, please help.
- Urgent car dies when I first try to start it!!!!!
- knocking problem under acceleration
- No acceleration
- correct operating temp for a 2001 lesabre?... and coolant leak
- still have a bad miss
- fuel pump
- rear lower control arm ball joint
- Nut Size Help ????
- 1993 Spark Problem
- 92 HVAC controls non-responsive
- Gas pedal sticking
- NOISE: ONLY @top/TB end of engine, ONLY at start up, 3.8 '97 LeSabre
- harmonic balancer bolt
- Getting ready for a long drive
- 1993 Buick Le Sabre won't start
- 2001 LeSabre, possible oil leak... questions
- Vacuum diagram for 92 Lesabre
- 92 suspension question
- trouble code P1870
- 1994 Sputter/surging/stumbling issue
- 97 Lesabre stalls while driving
- Trouble codes on a 1993 Lesabre
- EGR was bad replaced and still stalling HELP
- 1997 3.8 headlamp problem
- 92 Dies when turning on headlights!!!
- O-rings inside fuel rail quick disconnects
- 95 buick Lasabre please help
- 92 LeSabre Stalling - MAF Code
- camshaft
- 1997 Buick LaSabre Heater Control
- Suds coming through bottom ac vents when in car wash with ac on....
- Case Closed
- Chime stays on constantly
- Rough Idle and runs rough around 55
- oil leak and shaking
- 97 Buick LeSabre Won't Start
- Fuel Tank Capacity?
- Lowering the Thermostat
- Recirc stuck on open position
- gas gauge wacky?
- 300 lb safe dropped on Buick LeSabre
- Front wheel studs
- horn fuse
- 85 AC/Heat controls
- Supercharger questions.
- Any way to get both high and low beams?
- Last problem now... LOL, at 65mph engine sputters, and 3 crank cold crank
- Clicking Sound When I Accelerate?
- Tranny Flush
- stalling problems
- 97 lesabre dies while driving
- Turn off security light
- security light flashing
- 98 3800 II, How long will my Intake last?
- 94 Buick climate control gremlins
- fuse diagram for 1994 buick lesabre
- rusting out
- Ac vents were fine and now only defroster blows
Automotive Network, Inc., Copyright ©2013
