View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14
  1. belt tensioner +coolant lines removal on a 99
  2. 79 Secondary Coil
  3. gas pedal sticking
  4. '87 - Inst Panel problems when dimmer is on
  5. Strange Ticking Noise, Goes and Comes
  6. 94 LeSabre
  7. 94 LeSabre
  8. oil selection
  9. Autozone lists recall but can't get the info
  10. Door Poppers
  11. 00 lesabre will not start
  12. One more stalled Buick...
  13. Ken-co repair kit?
  14. Heal-A-Seal Gasket Repair
  15. Buicks Hate Bosch!
  16. '92 tranny: what is this sound?
  17. Has anyone ordered from oehq.com?
  18. Replacing struts..Monro, Gabriel
  19. 91 lesabre starts then turns off after 2 seconds
  20. Speed-related noise in 2001 Buick
  21. Replace coil packs or not???
  22. need help with wipers
  23. 95 fit a 96?
  24. keep it, or bail?
  25. Need Help From the PROS!!!
  26. Door parts
  27. '97 3800 engine squeal issue
  28. can't shift
  29. 91 LeSabre cuts out after warm up
  30. 1996 Buick Lesabre engine
  31. 1996 Buick Lesabre Blown Head Gasket
  32. Pimpin' My Buick
  33. DTC's on 95 Chevy Tahoe
  34. P 0507 Engine Code/intake replacement
  35. Fuel gauge acts weird
  36. air ride
  37. windsheild wipers wont shut off
  38. 1990 Buick LeSabre cold starting problem
  39. 1990 Lasabre inner door panel
  40. Are Radiatos a "Throw a way item" now?
  41. heater and a/c blower quit working
  42. heater and a/c blower quit working
  43. 97 lasabre fuel pump amperage
  44. grinding noise...
  45. Leaking fluids overnight????? help!@!
  46. 94 LeSabre- starts, shuts off right away
  47. power seat
  48. 2001-Tranny/Computer Dying?
  49. 91 rear brakes
  50. performance
  51. new to forum
  52. Dex-Cool and Sludge
  53. 1994 Buick Lesabre Custom
  54. 1986 Buick LeSabre
  55. LeSabre 94 dies sometimes
  56. 1994 Buick Lesabre Custom Interchangable Parts
  57. Clean oil in pistons 5 & 6
  58. 97 buick door locking system
  59. 89 century runs rich after warmed up(no response on century forum)
  60. '87 LeSabre - Problems shifting 2nd->3rd when cold
  61. Drive Ratio from: 2.95 to 3.05 ?
  62. 2000 lesabre
  63. Starter location???
  64. 1990 into a 1986 3.8
  65. '00 "garage lurch" need help PLEASE!!
  66. Air vent buttons troubles
  67. Buick Lesabre custom
  68. 2001 Buick Lesabre Delco Theftlock Help!
  69. abs problems
  70. 98 lesabre limited...pcv location
  71. '87 - No Cruise Control
  72. thermistat position
  73. 92 lesabre, no air flow
  74. Can anybody tell me how to take the grill off my 99 lesabre??
  75. Slow Weak Window Motors on '90 Lesabre
  76. 97 Lesaber Belt
  77. what the bloody hell...My windshield wipers will NOT shut off!!
  78. Trouble codes: P0121, P0300, P1406
  79. Drivers Rear door, no power lock or window
  80. 1997 Buick LeSabre Digital Climate Control
  81. heater
  82. 1993 LeSabre Custom-several issues
  83. 96 Buick LeSabre Climate Control Trouble
  84. Voltage Problem
  85. 1995 LeSabre Custom Right Turn Vibration (Read In)
  86. 98 Buick Lesabre running rough and now not starting!
  87. 2000 LeSabre- no power to diagnostic port
  88. 1995 Buick LeSabre Electrical Problems
  89. 1994 Buick Lesabre won't start
  90. Windshield washer pump/rear side marker
  91. Which scanner to buy?
  92. Programing a Body Control Module
  93. Good parts needed at a good price
  94. 92 buick makes a dinging sound and break light stays on
  95. 98 le sabre lowering springs/better suspension
  96. Aircon or computer problem or ?
  97. Blowing white smoke
  98. 95 lesabre Growel :disappoin
  99. 1997 LaSabre radio doesn't work after battery disconnected - not anti theft problem.
  100. Power Window Problem
  101. PLENUM Intake Failure, What kind of fluid did you use?
  102. Difficulty Starting (Episode 2)
  103. T-Type questions
  104. 3800 C - Misses When Hot
  105. rims
  106. no fuel to injector rail
  107. wanna do an engine swap
  108. engine code
  109. Broken/Warped Plenum's all over the place
  110. blocking off egr valve ? any problems
  111. Aftermarket CD Player
  112. 95 Lasaber altenator output cuts in and out
  113. 93 Lesabre Transmission Replacement
  114. Drivers side floor wet
  115. Muffler
  116. 94 Lesabre - Code 1650 QDM2 failure, weird problems...
  117. 94 Lesabre - how to remove back seat?
  118. 97 No Park/tail Lites
  119. pipes
  120. 00 lesabre
  121. Scanner says, "Intermittent Misfire" What kind of crap is this?
  122. 95 Lesabre overdrive shudder/vibration
  123. 1990 lesabre heater problems emergency brake light
  124. Replace Power Steering Cooler
  125. transmitter
  126. 92 lesabre transmission no 3rd gear
  127. which vin motors leak plastic intake ?
  128. Weak Fuel PUMP - Confirmation?
  129. My 2002 Lesabre is a piece of crap
  130. 1988 LeSabre Limited with climate control - Relay or Blower Control Module
  131. 98 limited tranny stop working
  132. 2000 leasbre
  133. turn signal lever wiring
  134. 2000 LeSabre electrical system goes nuts!
  135. 2000 lesabre
  136. '87 LeSabre - absolutely horrible milage
  137. 00 lesabre
  138. 1992 buick lesabre program fob
  139. scan tool
  140. 2000 lesabre
  141. 92 LeSabre-engine stops while driving
  142. 1998 starting problem
  143. washer pump electrical
  144. Difficulty Starting
  145. 89 le sabre fuel system problems
  146. New Rims
  147. 91 LeSabre Code 41 Keeps Coming Back
  148. 92 LeSabre instrument cluster compatibility, general questions
  149. cover for defroster vent
  150. 94 LeSabre - Going bonkers?
  151. strange behavior from 92 lesabre -fuel filter or computer?
  152. 1996 LeSabre Water Pump
  153. Is this normal
  154. Lesabre wont start
  155. 00 LeSabre ABS/front hub question
  156. Rough starting w/loss of speedometer
  157. 1995 coil packs and Mod
  158. 2001 lesabre rear brake pad replacement
  159. Buick Coil Pack test
  160. Dome Kight Hell
  161. 01 Buick La Sabre Fuel Level Sensor
  162. Replacing AC compressor
  163. 01 La Sabre Fuel Sensor
  164. 1995 buick lesabre struts
  165. 2002 Won't start on first try!
  166. fuel filter?? 97 lesabre 3.8
  167. Starting Issues - Please Help
  168. 93 Lesabre No heat
  169. 2001 Limited transmission woes
  170. Buick 350 to Chevy 350
  171. 1990 LeSabre electrical problem
  172. 2000 Lesabre battery location
  173. I'd call it a fludder in the front right.
  174. 97 smelling gas after driving found problem
  175. If I take out a fuse, will I get a check engin light?
  176. Lesabre gone crazy
  177. Headliner removal/dropping
  178. front end vibration
  179. 2003 LeSabre ABS/Traction Off/Brake lights remain on
  180. Headlights not working
  181. 1993 LeSabre - Electrical Problem
  182. 2004 lesabre airbags
  183. 1994 LeSabre No Spark
  184. Engine Vibration
  185. 2nd CV axle in 2 months
  186. Head Lights Won't Come On
  187. Plug wires
  188. abs brake problem
  189. Custom Wind Deflectors
  190. smelly exhaust
  191. Passenger gets maximum heat all the time
  192. Fuse box location
  193. Question about brakes/hesitation
  194. 2003 lasabre tranny problem
  195. Millage with your 3800
  196. What Are These Holes In Dashboard
  197. Climate Control
  198. Keyless Entry
  199. Troubleshooting Heated Seat
  200. weird problem w/ my '95 lesabre
  201. Auto Leveling
  202. What is "Twilight Sentenial"?
  203. Help Need Louder Muffler
  204. buick lesabre
  205. HELP with decision
  206. how to change 95 lesaber heater hoses ?
  207. Anyone have advice / guidance on how to change a water pump (91 Lesabre)
  208. '97 LeSabre miss
  209. 89 lesabre- front end shimmy
  210. What is this "Reset Oil Button" for??
  211. Motor Oil
  212. Infl.Rest. light Stays On
  213. 96 Buick LeSabre trouble starting
  214. help? 1989 buick lesabre limited
  215. 91 Lesabre won't start
  216. 90 28,000 miles backfires on hard accell
  217. Custom SG
  218. My First Buick
  219. Trunk Leaking
  220. resistor chip keys
  221. 92 LeSabre A/C auto activation Logic
  222. 94 lesabre idling problems
  223. '93 Lesabre hesitates in the begining
  224. 1998 to 2000 Lesabre, Any known Chronic problems ?
  225. Tune UP Time?? or Something Else?
  226. Key in / headlights on chime
  227. '96 lesabre turbo/supercharger
  228. new exhaust/lighten the car
  229. 2001 lesabre rear window operation
  230. Type of Battery(s?) for LeSabre FOB?
  231. What,Where is the DLC connector?
  232. 90 Buick Lesabre - Starting problems
  233. 2000 Buick Lesabre Custom NO Heat Heater Core fine
  234. 88 Lesabre Parts
  235. 95 LeSabre engine stalls 5sec after cold start
  236. inner tie-rod on a 97
  237. Preventative Repairs?
  238. Help!!! 1994 LeSabre wont stay runing/hard starts
  239. Egr Question, Need Help Asap
  240. Transmission Woes
  241. cold air intake
  242. Power Window troubles
  243. Overhead Lights
  244. Overhead Lights
  245. 2000 Buick Lesabre Dashboard Came loose
  246. 92 Lesabre...intermittently dies..cranks but no start
  247. 92 Dash Lights
  248. 89' Lesabre- "Lean exhaust" trouble...plz read
  249. 98 Lesabre
  250. 92 lesabre a/c not turning on. Defaults to ECONO
