View Full Version : LeSabre
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16
  1. Right side half-shaft axle on '90 Lesabre
  2. Speedometer Slightly Off?
  3. Re: changing the plentum - Bnaylor?
  4. 97 LeSabre Headlight Installation help needed
  5. Cold Start
  6. Ball-joint replacement
  7. Looking for A/C Fuse & Relay Box
  8. 98 w/81k miles
  9. Help Lesabre Will Not Fire!
  10. 98 lasabre water pump bolt
  11. Re: Cam sensor code
  12. Electric questions
  13. LeSabre - turn signal problem
  14. 94 lasabre windown
  15. 94 lasabre trunk problems
  16. 94 Lesabre Battery!
  17. Front end
  18. 89 Lesabre, long start, popping at hwy speed
  19. 94 lesabre alternator
  20. parking lights simple question
  21. Leveling System
  22. Antenna and Radio problems
  23. rim size
  24. Help Reprogramming Remote-2000 Buick LeSabre
  25. 94 buick lesabre-brake pedal goes way down-left front/right rear wheels only braking
  26. 93 LeSabre Flasher
  27. 1994 Lesabre Trouble Codes 321 and 361
  28. Trouble codes for 1995 Lesabre
  29. 92 Buick Lesabre
  30. 95 Lesabre A/C Heater Problem
  31. 1992 lesabre batter going dead
  32. 95 lesabre no start
  33. 91 Buick Steering Wheel wobling
  34. 93 Buick won't go into gear!!!
  35. 95 Lesabre vibration. At wits end!
  36. gas cap loose
  37. 93 lesabre front end problems
  38. 92, Blower motor intermidiatly off and on
  39. 97 buick lesabre cluster
  40. supercharger
  41. 1993 Lesabre, Occasional Tranny locking
  42. 97 Lesabre gas
  43. 2001 LaSabre - Odd Temperature Issue
  44. Headliner size difference b/w 2dr and 4dr
  45. 98 rear shock removal?
  46. Door catch problem
  47. Opinions on a '93, please!
  48. 92 lesabre dies at light
  49. P1406 code fixed
  50. ignition relay
  51. 97 Lesabre Gas Line Tank to Fuel Filter
  52. '93 Le Sabre Vacuum Hose Issues
  53. Tranny Service
  54. instrument cluster upgrade?
  55. LeSabre brake issues
  56. Tranmission Gone Nutty
  57. 1993 Lesabre heating problems
  58. Switching the Color of the Dash
  59. HELP!! 1997 LeSabre Squealing Squeaking Noise Drives Me Crazy
  60. Delco Alternator--MK 2
  61. 2001 Buick LeSabre - Headllight relay prob??
  62. '97 Lesabre
  63. Broken starter housing...
  64. serious battery drain
  65. LeSabre--The Granny Problem
  66. 92 Lesabre AC/Heat won't blow?
  67. 98 lasabre water pump
  68. Mass Airflow Sensor
  69. 93 won't start at all
  70. What is the O.E. tire size for 1994 LeSabre?
  71. starting problems 1997 Lesabre
  72. GM Stock Cars--Ballad of the Ghetto Rides
  73. Rear seats, and speakers...
  74. Brake Indicator Light Beeps When Accelerating
  75. Removal 2000 Lesabra Steering Wheel Buttons
  76. overdrive
  77. Is Resistance Futile?
  78. 95 lesabre leaking oil??
  79. 2000 LeSabre Brakes
  80. Dual Climate Control - No heat passenger dash
  81. 88 LeSabre - Replacing Flasher Unit
  82. 2000 LeSabre, whine when turning
  83. '92 LeSabre DEADLY BRAKES!
  84. Engine Stalls - LeSabre93 Custom
  85. Buick LeSabre will not start, mechanics stumped
  86. 86 3.8 Le Sabre Won't Crank, Start.
  87. no start, wiggle key , START!!!
  88. What Brand of O2 Sensor Do You Use?
  89. Dash pad removal? 00 Lesabre
  90. Mysteries of the 92 LeSabre
  91. 97 Lesabre power steering fluid leak
  92. RPM "flare" when tranny shifts into OD...
  93. Code P1361 Returned and Completely Cuts Out on Bumpy Roads
  94. Possible Remote Trunk?
  95. 93 Lesabre Thermostat - Temp Gauge
  96. Power steering problem?
  97. Thermostat For '97 Lesabre
  98. 92 LeSabre kills while driving
  99. lesabre Limited 97 A/C problem
  100. Traction Off??..
  101. Wont Start!!
  102. Air exchange door location
  103. 90 Buick LeSabre shudder@35-40MPH
  104. Need help unclogging drain holes
  105. 92 lesabre tranny maintenence question
  106. 1994 buick lesarbe blower motor
  107. 94 Lesabre Engine/Trans problem???
  108. 1995 Lesabre motor surging and dying at stops
  109. '94 LeSabre Stalling, other bizarre issues
  110. 1992 LeSabre Trouble Code 13 & 44
  111. 94 Lesabre Alignment
  112. Car Keeps Cutting Off
  113. Can ecm be checked?
  114. changing rear struts on 87 lesabre
  115. 94 LeSabre Scanned!
  116. 94 LeSabre Headaches!
  117. Electric Supercharger
  118. 1994 Buick LeSabre Limited...
  119. Bad mileage... bad, bad mileage
  120. HID Xenon Kits.. aww shnaps!
  121. How do I check ignition coils??
  122. Posting in Closed or Outdated Threads
  123. No heat on passenger side 95 lesabre
  124. 92 Le Saber - blower motor??
  125. Very odd tank fill-up problem
  126. need help with 92 lesabre
  127. 93 Lesabre Glove Box Door Key Cylinder R/R
  128. 1988 Buick LeSabre - Replacing heater core
  129. 1993 Buick Lesabre Keyless entry programming
  130. Scan tools for newbie ?
  131. 95 Lesabre intermitint OD problem
  132. Some More 94 lesabre problems
  133. 94 Buick Lesabre Problems!
  134. high flow catalytic converter..?
  135. 94 lesabre park lamps
  136. 92 Buick Le Sabre Limited FSM
  137. 97 lesabre Check engine light on
  138. How to get the brake booster out?
  139. engine light always on
  140. 94 Lesabre with battery warning light
  141. 87 lesabre rack and pinion question
  142. Maf or TPs?
  143. park avenue horns?
  144. Stall during turns
  145. 1992 LeSabre RKE
  146. brake lines
  147. Because theres no one who visits VW
  148. Bleeding brakes - 1994 LeSabre - proper sequence?
  149. New aftermarket headunit
  150. 1990buick lesabre electrical problem
  151. Torque spec for 94 Lesabre brake caliper?
  152. 1995 LeSabre Water Pump Seized!!!
  153. Turbonator!
  154. 1990 LeSabre starter issues
  155. 92 LeSabre Location of ECM Module?
  156. buzzing noise
  157. Help ME!!!
  158. New and Old Members Please Read
  159. Horn problem
  160. Backfiring 93 Lesabre
  161. Some fairly extensive brake work
  162. OBD 1 code format for 94 Lesabre v6 3.8L
  163. 01 locks me out
  164. 2000 Lesabre - Radiator Petcock & Eng Block Drain ??
  165. Horn
  166. Bad stumble under load
  167. 1990 LeSabre.....Any advice is apprieciated;)
  168. Keyless Remote
  169. Used muffler ok?
  170. 1995 LeSabre Custom problem with wet conditions..
  171. 95 Lesabre Pass Key Problem
  172. 91 Buick LeSabre Transmission
  173. Noisy A/C Compressor Clutch
  174. Alarm keeps going off
  175. Air bag light on?
  176. fastest way to go 0-60
  177. 1994 Buick Lesabre - Headlight Issues
  178. 1999 LeSabre
  179. '01 LeSabre - McPherson Struts
  180. 95 LeSabre ABS problem
  181. Rear driver side tire wont move??
  182. A/C Vacum.
  183. 94 LeSabre starting problem
  184. 1995 Le Sabre trunk remote and dash release won't work
  185. 2002 LeSabre Air Conditioning Problem
  186. No Panel Vents
  187. Passkey Help
  188. Check Engine Light 1997 LeSabre
  189. 95 LeSabre not starting randomly
  190. Series 1 cold air intake
  191. Vacume leak that I can only hear when ac is on....
  192. Hubcap Question
  193. SparkPlugs - Series II Help! :-)
  194. '01 Lesabre transmission problems
  195. '01 Lesabre rear window motor
  196. '93 LeSabre Blinker trouble
  197. '93 LeSabre Silly Windows
  198. 97 la sabre ruff idol after repairs
  199. Causes for bad mileage
  200. Odd drivetrain noise
  201. 1990 buick lasaber not starting
  202. AC question
  203. 93' lesabre wont start after going through big puddle
  204. 99 LeSabre Fuel Pump
  205. stuck rear wheel hub assembly, 93 lesabre
  206. Custom air intake.
  207. 96 Check Engine light on
  208. 95 Buick LeSabre Custom with Benz mirrors!?
  209. AC not working
  210. key lock problem
  211. 97 la sabre no power
  212. How difficult is to replace ECM?
  213. Engine swap? What fits in a 95 LeSabre Custom?
  214. VATS error
  215. Horns Inoperative...
  216. Is a 94 tranny a direct swap into 92?
  217. 93 lesabre steering problem
  218. exhaust?
  219. Making the SERIES 1 faster??
  220. Transmission Control Module
  221. Dynaride?
  222. Rapid Velocity Performance Module?
  223. 92 lesabre not starting
  224. Will washers mess my battery up?
  225. speakers?
  226. Radio Antena
  227. Harmonic Balancer Disintegrated! Is this normal
  228. 97 LeSabre horn, lights, locking problems
  229. Problem going into Drive or Reverse from Park when cold...
  230. electric problem with turn signals and reverse lights
  231. 94 Lesabre NO ONE CAN FIGURE OUT
  232. 95 LeSabre door panels
  233. 1997 lesabre that just dies out when driving
  234. car part
  235. 1990 Buick LeSabre
  236. Climate control for 1997 Limited Lesabre
  237. '94 ECM Replacement help
  238. 99 Lesabre engine hesitates at idle...
  239. 97 Lesabre: Poor Gas Mileage, Smell of Gas
  240. 1999 Cassette Radio/Cd Player Removal
  241. car audio system
  242. part location? Please help!!!!!!!!!!!!!!!!!!!!!!
  243. ECM Repeatedly Failing
  244. Dr. autoparts intake manifold
  245. Various questions.. door pillars, instrument lighting, dash paint, mirrors..
  246. catalytic converter
  247. Lesabre engine dies at odd times
  248. Rear brakes locking up?
  249. Crash
  250. Vents not working?
