View Full Version : LeSabre
Pages :
1 2 3 4 5 [ 6]
7 8 9 10 11 12 13 14 15 16 17 18 19
- MY CAR DIED......can I sue GM for not recalling the UIM?
- Gas pedal hard to push
- 95 LeSabre, DRLs do NOT shut off
- 1997 Lesabre Wiring/Climate Controls
- Rain X Latitude Wipers for 2001 Lesabre
- Just changed fuel sender. Too sensitive!
- Broke the latch on the console
- Rear coil spring question
- ICM testing
- 2002 LeSabre directional issue....
- 2001 lesabre evap canister location
- 2000 Lesabre Trunk leak on right side of trunk
- buick sputtering and now wont start
- 2001 Lesabre Gas Gauge part two
- 2001 - lights flickering every now and then
- service engine soon light- 2002 buick lesabre
- Drain holes in front fenders
- 1989 LeSabre loping
- 93 LeSabre power steering problems
- Drip, Drip, Drip....Follow the Drip!
- 3.8 Series II identification
- '97 Headlights
- abs pump assy
- harmonic balancer
- Struts and shock auto leveling replacement?
- UIM Replacement
- 1995 lesaber air conditioning compressor
- Drilling the firewall for Subs
- Speedometer problem
- 2000 Suspension Question
- Mirror with outside temp want to replace
- 1994 LeSabre Shop Manual
- 1988 V-6 Buick LaSabre Cruise Control Inoperable
- 94 Buick Lesabre 3.8 Upon RPM increase car stumbles and bumbles, no power at all.
- Bang the Drum slowly.......
- 1990 Buick Lesabre won't start
- Rear Brake Rotors
- Shake, rattle, and roll..........
- 92 Buick Electrical Problem
- * * 2000 with no guage lights
- Upper Cylinder head Gasket Repair kit Fel Pro
- Oil Pressure Sensor Location
- Running Rich?
- misfire
- photos of 1992 lesabre 3800 series 1 engine bay
- Need DTC (CODES) Help
- 2001 lesabre
- got to hot, head or intake gasket???
- 98 lesabre hvac codes
- Decoding paper tag on springs
- Timing
- gas leak from fuel filter 97 lesabre
- dash pad seperating
- 94 Lesabre-no start
- 2000 Lesabre Transmission shutter
- Dash popping up in front of driver
- Air rushing sound when cold
- 1997 LeSabre Theft Deterrent Problems - Trunk
- 97 Buick Lesabre
- Spring interchange
- 1988 Lesabre Cruise Control problems
- 2001 lesabre "Traction Off" light
- Door actuator left hot air
- air conditionor problems
- 00 Heated Seat
- Engine Swap: Help with choices and other questions
- 94 lesabre infl rest intermittent
- Clunking sound from front end
- No air through vent duct
- 2000 Buick LeSabre security light.
- Buick lesabre 94 idles but no power
- Can your ac cause low coolant in the reservoir?
- Ticking 97 Lesabre
- When to change a timing chain.....
- 97 lesabre engine computer compatibility
- 2000 Buick LeSabre Limited window disfunction
- Radio goes silent - 2000 LeSabre
- 04 Lesabre - Strange Grinding Noise On Acceleration
- fuel pump
- High Idle
- 2002 Lesabre....Good buy?
- Need HELP removing trim
- Blown motor. What do these symptoms mean?
- 2000 Buick LeSabre Limited Door Locks going Crazy
- mysterious mid 90's trim options
- bad wheel bearing hub or bad CV joint 01 LeSabre
- Code PO1870
- 1992 Lesabre - List of Issues
- 1988 lesabre harmonic balancer
- 3800 Engine swap troubles. Need GM Guru
- Parts for 1985 Collector's Edition
- Fuel Filter Location 2000
- Dual Climate Control
- Changed fuel filter and gas brand...Great gas mileage!!
- need help, fuel gauge jumping all around
- 91 lesabre starting probs
- '97 PCV problem
- 94 lesabre electrical problems, very strange
- Anything else I can check for Cruise problem?
- Free Online Service Manuals including TSB and RECALL
- 2002 Buick LeSabre Battery
- Need help 2000 lesabre
- Intermittent Window, Door Lock, Window Problem
- Intake Manifold Removal
- 94 lesabre brake bleeding
- How do I replace thermostat? 1990 leSabre
- Urgent!!! Fuel Resending Unit Question
- How do I replace a power steering cooler?
- Daytime Running Light problem
- check tire pressure alarm
- PLEASE HELP! Idling and Stalling Problem!!!
- 97 How to remove relays
- Ignition Fuse & Starting Failure
- 96 3.8 MAP Sensor question
- P0440 Code
- 92 trannie trouble
- '89 Running Rich
- 2004 LeSabre Cruise not working. Where to look?
- Does the fan run on vacuum?
- Front and back caliper bolt torque
- LeSabre 1993
- Air Compressor Clutch 98 LeSabre
- 1991 lesabre stating probs
- Fuel related?
- 92 LeSabre electric window problem
- 91 LeSabre Tilt Wheel: Not The Three Bolts
- Air Hose to Shocks
- 98 Le Sabre broken front sway/stabilizer bar
- timing set nut size
- 1988 le sabre seat not wk'ing
- 94 Lesabre
- 2000 Lesabre lost power during driving
- 2002 Lesabre AC blower problem
- High Idle--Please Help
- 93 LaSabre sounds like a Diesel
- Horn Blasting Spontaneously
- AC adapter
- installing down stream o2 sensor
- TPS problem 95 Lesabre
- 98 LeSabre won't start
- 2004 lesabre ticking upon acceleration
- 2002 Limited RDS Radio Aux Port Auxilary
- 1991 Buick wont start
- About to do suspension work, what else...
- 92 LeSabre Hood Latch
- The tire wobble check.
- code reader for 95 Lesabre
- Suspension/control problems
- 05 LeSabre shocks
- 93 Lesabre, need more HVAC airflow
- 02 lesabre 3.8 oil light /fuel gauge problem
- Is there a way to figure Overdrive or not at a certain speed?
- !992 Buick LeSabre A/C problem
- 1999 3.8L intermittent P0303 code
- 2000 LeSabre Headlight Switch Repair
- 95 LeSabre - Diagram of Fuse Panel Available?
- 1997 lesabre a/c compressor bypass?
- 2000 buick lasabre intermittent starting problem
- Remove Window Paint - But Can't See It
- 440-t4 trans parts needed...
- 1991 4t60 TCC wiring
- coolant leak/check engine light
- Steering Wheel Lights - I have replaced bulbs
- Heater Control Illumination
- wheel whistling sound
- 95 LeSabre - Interior Lights Stay On
- 96 LeSabre brake light and chime...
- what temp should cooling fans come on
- 97 LaSabre Battery Drain...
- Help with fuel level sending unit replacement
- 1995 Buick Lesabre Idling Fast And Speedometer Not Working
- Ash Tray Light
- 97 Lesabre Hard Starting
- Christmas Tree lights from A/C Control Panel, '93 Lesabre
- knocking noise
- AC problem help needed 2000 Buick Lesabre
- Any way to change all the fluid in Transmission 1997
- P.S pump noise
- 2000 Le Sabre security light issue
- 1989 rear disc brakes?
- 92 LeSabre...PLEASE HELP
- 2001 Lesabre leaky intake manifold
- 2000 buick lesabre service stability system dic message
- engine rattle
- TPS (Throttle Position Sensor)
- 95 with bad crankshaft seal...
- Where to buy new headlamp dashboard switch? (year 2000)
- 1992 Buick Lesabre Window Problems
- Upper Intake Coolant Leak
- Re: `95 Lesabre engine misfire/shaking badly occassionally/randomly
- How to remove exterior rear tail light assembly 1994 LeSabre
- 95 LeSabre Oil leak on pass side above oil filter...
- 1993 LeSabre TB fastener torque
- 99 LeSabre Turning Noise
- 92 lesbre flooding out?
- Help with the wiring of the rear
- Axle Nut Torque
- 1993 Buick Lesabre Front Powered seats not working
- A/C Compressor
- 2000 Buick Lesabre Not Starting
- How do I disable the airbag on a 99 lesabre?
- 2001 Lesabre turn lamp replacement
- 97 LeSabre sucks air through oil fill?
- 1995 Alternator Problem
- rebuilding a power steering pump
- 1992 Lesbre stalls
- 92 Compatability
- 1992 LeSabre loss of power/missing and stalling
- 1998 LaSabre-Just defrost and floor vents work
- AC compressor won't stay on
- 1997 lesbare noise in front end when turning right goes away when braking
- '94 lesabre custom problems
- New here with some questions
- Loose Gas Cap Code
- 1996, Dual ACC - passenger side heat always on
- Horn is stuck on....please help.
- Clicking noise from ventilation system
- 2001 LeSabre ALC "clicking noise" question
- 2002 Lesabre spark plug wires
- 2000 buick blend air door
- 2000 Buick Lesabre a/c not cold on drivers side
- confused and going crazey please help
- 1995 buick lesabre air conditioning clutch
- 94 Le Sabre Trans problem
- $115 to resurface front rotors????
- Spare Tire Well Plate
- 1995 Buick Lesabre won't start
- Antenna Problems
- Upper intake rattle.
- Actuator
- Buick Lesabre Computer reprogrammed
- 93 buick lesabre hood wont open
- Climate Control Puzzle
- rattling noise when engine hot
- 93 fuel filter location
- Interior lights don't go out
- 97 MAP Sensor
- changing ignition switch 95 lesabre
- 2000 LeSabre driver side seat belt quest
- does my 93 lesabre have a diagnostic plug
- 3 quick questions about out 2001 LeSabre
- 93 lesabre makes noise after starting cold
- 97 lesabre: Coolant in oil
- Heat or AC dash vents inop
- 1995 buick Lesabre remote programming instructions.
- throttle position sensor
- 1996 LeSabre - high idle when in gear
- Shifting problem (up/down) 94 Lesabre
- 2003 LeSabre power lock problems
- 2001 LeSabre electrical problems
