Our Community is 705,000 Strong. Join Us.
View Full Version : LeSabre
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Can't find coolant fan relay-1988 Le Sabre
  2. 01 Lesabre trans 2-3 hesitation
  3. UIM story, bad garages...lil funny
  4. 1993 Driver's door key lock
  5. 1994 - Lesabre, Fuel pump?
  6. 84 lesabre v8 coupe value?
  7. 97' Buick lesabre will start but will not stay running.. HELP ME !!
  8. 2000 Lesabre Limited-dash controls go crazy
  9. 93 lesabre won't move
  10. Temperature incorrect on Comfortemp Display
  11. Where is the flasher module on a 1999 Lasabre
  12. 1995 Buick Le Sabre, Lights
  13. 1995 Buick Le Sabre, sloppy gas pedal
  14. Coolant goes above max hot line when running...
  15. Need Help Please!!!
  16. dead battery 99 lesabre
  17. LCD temp control display
  18. 02 Lesabre Alternator gets hot
  19. Weird Power Steering
  20. engine knock
  21. 2004 Buick lesabre speedometer problems
  22. jon 111
  23. P0404 and P0405
  24. 98 buick lesabre upper and lower intake
  25. tranny shudder fix?
  26. 1997 lesabre electrical transmission problem
  27. 90 Lesabre deceleration miss......
  28. engine temp guage showing lil cool
  29. does fram xtra guard have drain back valves in them?
  30. HVAC won't switch to Heat/floor vents?
  31. need to replace the heater core???
  32. Lifter noise at cold start up
  33. Engine vibration at idle
  34. Idle not steady - moves up/down 150rpm
  35. Frozen gas lines?! What is there to do?
  36. Cigarette lighter 2003 Lesabre
  37. Re: need help with wipers II
  38. REPOST 2 OF UMI JOB pics inside (maybe)
  39. tranny problem or engine/tranny mount?
  40. AC compressor noise
  41. Blower Mystery... 1992 Lesabre (Getting COLD in ND)
  42. Strange Vibration - 2002 LeSabre
  43. You guys or gals are great!
  44. 1994 Lesabre....question about starting.
  45. 1994 Lesabre Intake Manifold....Problem Solved!
  46. Looking at a 95 Lasabre, Need help
  47. cold start problem
  48. Radio stays on with key out?
  49. UIM gasket
  50. 91 Lesabre stalling, sputtering, hard to start
  51. 88 Buick LeSabre Starter Replacement
  52. 1997 Tensioner Adjustment
  53. Upgrade Radio Advice Please : 1994
  54. Hard brake pedal and comp code 1406
  55. coolant loss 1997 popular problem i guess
  56. Re: Plugs and Wires sounds easy huh?? Take Two
  57. Door panel leaking - solution
  58. massive vibration on acceleration and when shifting into overdrive
  59. Coolant system pressure test?
  60. Tie-rod ends on '90 Lesabre
  61. 97 Lesabre headlight / turn signal problem
  62. 2000 LeSabre help no heat
  63. Lifter noise (cold) and misfire code 301
  64. '97 UIM letting go
  65. Comfortemp Display 95 Buick Lesabre
  66. Help with 92 LeSabre
  67. Harsh shift in reverse only when hot
  68. 98 LeSabre voltage gage variation
  69. Need Help - 2002 LeSabre
  70. 97 Lesebre Power Steering Mount Bracket
  71. No Ext Temp reading??
  72. Buick LeSabre 98 With 230k Miles on it. got it or not
  73. Please Help! 96 Park Ave Motor into 97 leSabre
  74. HVAC code 38 Serial Data failure to PCM
  75. odd service engine soon light
  76. high idle on cold start
  77. Replacing LCDs in HVAC and Radio
  78. Fuel Pump
  79. Vacuum sender to Brake Canister
  80. code 38 on HVAC control
  81. P0171 Dtc
  82. Fuel tanks interchangeable???
  83. 1995 Buick LeSabre Hybrid check engine light on first drive of the day
  84. MY CAR DIED......can I sue GM for not recalling the UIM?
  85. Gas pedal hard to push
  86. 95 LeSabre, DRLs do NOT shut off
  87. 1997 Lesabre Wiring/Climate Controls
  88. Rain X Latitude Wipers for 2001 Lesabre
  89. Just changed fuel sender. Too sensitive!
  90. Broke the latch on the console
  91. Rear coil spring question
  92. ICM testing
  93. 2002 LeSabre directional issue....
  94. 2001 lesabre evap canister location
  95. 2000 Lesabre Trunk leak on right side of trunk
  96. buick sputtering and now wont start
  97. 2001 Lesabre Gas Gauge part two
  98. 2001 - lights flickering every now and then
  99. service engine soon light- 2002 buick lesabre
  100. Drain holes in front fenders
  101. 1989 LeSabre loping
  102. 93 LeSabre power steering problems
  103. Drip, Drip, Drip....Follow the Drip!
  104. 3.8 Series II identification
  105. '97 Headlights
  106. abs pump assy
  107. harmonic balancer
  108. Struts and shock auto leveling replacement?
  109. UIM Replacement
  110. 1995 lesaber air conditioning compressor
  111. Drilling the firewall for Subs
  112. Speedometer problem
  113. 2000 Suspension Question
  114. Mirror with outside temp want to replace
  115. 1994 LeSabre Shop Manual
  116. 1988 V-6 Buick LaSabre Cruise Control Inoperable
  117. 94 Buick Lesabre 3.8 Upon RPM increase car stumbles and bumbles, no power at all.
  118. Bang the Drum slowly.......
  119. 1990 Buick Lesabre won't start
  120. Rear Brake Rotors
  121. Shake, rattle, and roll..........
  122. 92 Buick Electrical Problem
  123. * * 2000 with no guage lights
  124. Upper Cylinder head Gasket Repair kit Fel Pro
  125. Oil Pressure Sensor Location
  126. Running Rich?
  127. misfire
  128. photos of 1992 lesabre 3800 series 1 engine bay
  129. Need DTC (CODES) Help
  130. 2001 lesabre
  131. got to hot, head or intake gasket???
  132. 98 lesabre hvac codes
  133. Decoding paper tag on springs
  134. Timing
  135. gas leak from fuel filter 97 lesabre
  136. dash pad seperating
  137. 94 Lesabre-no start
  138. 2000 Lesabre Transmission shutter
  139. Dash popping up in front of driver
  140. Air rushing sound when cold
  141. 1997 LeSabre Theft Deterrent Problems - Trunk
  142. 97 Buick Lesabre
  143. Spring interchange
  144. 1988 Lesabre Cruise Control problems
  145. 2001 lesabre "Traction Off" light
  146. Door actuator left hot air
  147. air conditionor problems
  148. 00 Heated Seat
  149. Engine Swap: Help with choices and other questions
  150. 94 lesabre infl rest intermittent
  151. Clunking sound from front end
  152. No air through vent duct
  153. 2000 Buick LeSabre security light.
  154. Buick lesabre 94 idles but no power
  155. Can your ac cause low coolant in the reservoir?
  156. Ticking 97 Lesabre
  157. When to change a timing chain.....
  158. 97 lesabre engine computer compatibility
  159. 2000 Buick LeSabre Limited window disfunction
  160. Radio goes silent - 2000 LeSabre
  161. 04 Lesabre - Strange Grinding Noise On Acceleration
  162. fuel pump
  163. High Idle
  164. 2002 Lesabre....Good buy?
  165. Need HELP removing trim
  166. Blown motor. What do these symptoms mean?
  167. 2000 Buick LeSabre Limited Door Locks going Crazy
  168. mysterious mid 90's trim options
  169. bad wheel bearing hub or bad CV joint 01 LeSabre
  170. Code PO1870
  171. 1992 Lesabre - List of Issues
  172. 1988 lesabre harmonic balancer
  173. 3800 Engine swap troubles. Need GM Guru
  174. Parts for 1985 Collector's Edition
  175. Fuel Filter Location 2000
  176. Dual Climate Control
  177. Changed fuel filter and gas brand...Great gas mileage!!
  178. need help, fuel gauge jumping all around
  179. 91 lesabre starting probs
  180. '97 PCV problem
  181. 94 lesabre electrical problems, very strange
  182. Anything else I can check for Cruise problem?
  183. Free Online Service Manuals including TSB and RECALL
  184. 2002 Buick LeSabre Battery
  185. Need help 2000 lesabre
  186. Intermittent Window, Door Lock, Window Problem
  187. Intake Manifold Removal
  188. 94 lesabre brake bleeding
  189. How do I replace thermostat? 1990 leSabre
  190. Urgent!!! Fuel Resending Unit Question
  191. How do I replace a power steering cooler?
  192. Daytime Running Light problem
  193. check tire pressure alarm
  194. PLEASE HELP! Idling and Stalling Problem!!!
  195. 97 How to remove relays
  196. Ignition Fuse & Starting Failure
  197. 96 3.8 MAP Sensor question
  198. P0440 Code
  199. 92 trannie trouble
  200. '89 Running Rich
  201. 2004 LeSabre Cruise not working. Where to look?
  202. Does the fan run on vacuum?
  203. Front and back caliper bolt torque
  204. LeSabre 1993
  205. Air Compressor Clutch 98 LeSabre
  206. 1991 lesabre stating probs
  207. Fuel related?
  208. 92 LeSabre electric window problem
  209. 91 LeSabre Tilt Wheel: Not The Three Bolts
  210. Air Hose to Shocks
  211. 98 Le Sabre broken front sway/stabilizer bar
  212. timing set nut size
  213. 1988 le sabre seat not wk'ing
  214. 94 Lesabre
  215. 2000 Lesabre lost power during driving
  216. 2002 Lesabre AC blower problem
  217. High Idle--Please Help
  218. 93 LaSabre sounds like a Diesel
  219. Horn Blasting Spontaneously
  220. AC adapter
  221. installing down stream o2 sensor
  222. TPS problem 95 Lesabre
  223. 98 LeSabre won't start
  224. 2004 lesabre ticking upon acceleration
  225. 2002 Limited RDS Radio Aux Port Auxilary
  226. 1991 Buick wont start
  227. About to do suspension work, what else...
  228. 92 LeSabre Hood Latch
  229. The tire wobble check.
  230. code reader for 95 Lesabre
  231. Suspension/control problems
  232. 05 LeSabre shocks
  233. 93 Lesabre, need more HVAC airflow
  234. 02 lesabre 3.8 oil light /fuel gauge problem
  235. Is there a way to figure Overdrive or not at a certain speed?
  236. !992 Buick LeSabre A/C problem
  237. 1999 3.8L intermittent P0303 code
  238. 2000 LeSabre Headlight Switch Repair
  239. 95 LeSabre - Diagram of Fuse Panel Available?
  240. 1997 lesabre a/c compressor bypass?
  241. 2000 buick lasabre intermittent starting problem
  242. Remove Window Paint - But Can't See It
  243. 440-t4 trans parts needed...
  244. 1991 4t60 TCC wiring
  245. coolant leak/check engine light
  246. Steering Wheel Lights - I have replaced bulbs
  247. Heater Control Illumination
  248. wheel whistling sound
  249. 95 LeSabre - Interior Lights Stay On
  250. 96 LeSabre brake light and chime...
