View Full Version : LeSabre
Pages :
1 2 3 4 [ 5]
6 7 8 9 10 11 12 13 14 15 16
- Loking For A Torque Converter And Tranny
- Sometimes car doesn't start, "Diesels" at begining
- Buick 2000 Cruise problem
- 1995 Buick lesabre dies out of the blue
- 1992 lasabre flasher
- "True" Dual Exhaust--A question
- '86 3.8l vin 3 performance & fuel economy poor
- Leather Seats In 97 LeSabre - Good Or Bad?
- Adding "Home-Built" Daytime Running Light Circuitry To 95 LeSabre
- Heated Seats 2000 Lesabre
- 92 Lesabre Limited overheats
- 1994 Buick LeSabre cutting off upon acceleration
- 2002 Buick LeSabre coolant leaks
- False EGR code ???
- 94 Lesabre Hesitating!
- 94 Lesabre Shutting Off!
- Broken Bolts
- Surging,bucking,hesitation All Speeds 1988 3800 T-type
- aftermarket body parts
- 1992 LeSabre - Power Steering Cooler
- Has anyone made their car quieter riding?
- LeSabre 1993
- 2000 intake manifold
- 2000 lesabre auto level
- Series II or Series I 3800 In My 1995 LeSabre?
- '97 Lesbare Alternator Going Bad?
- (1992) Left Cornering Lamp Stays On
- 1996 Buick LeSabre Air Conditioner Problem
- 87 LeSabre IGNITION will not turn to the ON position
- Programming spare remote
- 1993 Buick Lesabre AC Controls, Fixed it!
- Interior Cleaning
- 95 Le Sabre Radio
- Best option to get replacement keyless entry remote on a 97 LeSabre Limited?
- Heater problem 91 LeSabre
- Wire Wheels
- noise transmission
- '94 buick lasabre starts then stop immediately
- '97, intermittent stalling, MAP sensor code
- Shift Solenoid Valve Replacement
- Radio static on '95 lasebre
- 2005 LeSabre limited A/C problem
- 94 still stalling-3.8L Vin L
- harmonic balancer retaining nut size
- 2000 LeSabre Interior Lighting Problem
- 1992 LeSabre Diagnostics
- 86 flywheel vs 87 flywheel, both 3.8
- 1992 buick lesabre timing gear assy
- 00 Lasabre Driving lights
- Any known problems with 2001 Le Sabre?
- how do you read trouble codes on 87 buick lesabres
- radiator drain location 2000 lasabre
- '91 LeSabre service engine light & idle
- 94' Buick Lesabre PCM wires cut, why?
- Anybody tried a CD Manual?
- 2000 lasabre service engine soon light on and will not start
- Doesn't look like a LeSabre to me....
- Error Code P0101 and Idle Air Controller
- Stay with original ac delco plugs
- 97 Buick Lesabre Ltd dragging/hesitanting/stalling
- 93 LeSabre no spark
- 1992 buick lesabre code 41
- 92 Buick Lesabre, thought my alternator died, but now what??? Very strange
- Air Conditioner Moody
- 1995 LeSabre Vibrates/Spudders at 35, 65 MPH
- 98 Lesabre ACC display flashing
- Emergency Brake Extraction
- 97 LeSabre won't start after fixing coolant in cylinder problem
- 1989 LeSabre Massive Coolant Leak at Timing Chain Cover (Front Cover)
- Door speaker removal.
- torque converter clutch control sensor can they cause damage when bad?
- 98 lesabre map sensor oily? why go bad
- Key in-start, nothing. Security light stays on
- 1995 Buick LaSabre - Heater Core Replace
- ABS Wheel Sensor Resistance '97 Lesabre
- What size are the speakers in a 99 Lesabre?
- 93 LeSabre transmission problems
- '92 LeSabre Ignition Switch
- Problem after UIM Replacement
- Light Power Point
- Ding, Ding keeps going after key is removed
- system lean "Bank 1"
- 94 lesabre, hesitation starting and driving
- '95 LeSabre Odd Trans Problem
- 2001 Buick Lesabre brakes
- '98 La Sabre - repair or replace rocker panels?
- 92 Buick Will Only Start Every Other Day
- Temp control sensor 97 lesabre
- Cost of Dynaride Suspension
- Need advice
- How much for a tranny?
- K & N air filter?
- clunking noise going over bumps
- Left Turn Signal
- What do I need, a Cylinder or a Switch?
- Speaker mountings in front door of 94 LeSabre?
- 2000 "chugs" when gas let off
- 93 Buick Lesabre Engine rattle
- No Brakes!
- 93 lesabre tranny problems....help!!!
- 1997 LaSabre Limited, AC fades...
- key fob problem
- Deep Impact
- Need help removing something
- 1995 Buick LeSabre
- S.O.S. Need Help W/Alternater Issue
- Torque converter circuit
- '95 LeSabre problems
- 94 Le Sabre Acting strange...need help
- 97 buick lesabre wont start
- Need help with a seatbelt problem!
- UIM Lawsuit
- Removing sparkplugs
- Where to Buy a Fuel Gauge Sending Unit?
- Need Help finding wool seat covers
- Cost of replacing passkey
- Flippin' rear VC!!!
- Electric Trunk Release Device Problem
- Spoiling my Ride
- Brake/Blinker problems PLEASE ASSIST. 2004 buik lesabre
- How to remove back seat?
- 1993 Fuel Filter
- 1993 LeSabre Seat Swap?
- 98 Custom, Chip in key going bad?
- 2001 Lesabre Rear Brake Noise
- Broke Turn Signal on 98 Custom
- 2000 Buick LeSabre Intermittent start, strange behavior! PLS HELP!
- 1995 Buick Lesabre Limited
- 92 Buick Lesabre Limited. wireless remote control
- 1992 LeSabre Custom Temperature Sending Unit
- How to Troubleshoot Cruise Control on a 1997
- Subwoofer and amplifier installation
- 94 Buick Le'Sabre 3800 engine won't start
- 97 Lesabre dies, will not restart, but will restart later. No codes
- Need to Rehab a 1990 LeSabre Custom
- Full Metal Body
- UIM/LIM assembly
- 2000 Buick whining noise at high speed
- 97 Lesabre(limited) climate controller problem
- 1995 Lesabre Key/Security light help
- UIM Kit Comparison? GM, APN, Dorman
- Problem with the gas gauge
- 1997 Buick Lesabre- Please help
- One more question
- Help...I cant get my wipers off.
- Power Window Motor Issues 1990 Buick LeSabre Custom
- 97 Lesabre whistle /squeal driving me crazy
- 98 LeSabre engine
- HB removal tool for 94 Lesabre 3.8
- OBD question 95 Lesabre
- 98 LeSabre engine code question
- Help, 97 Buick LaSabre water pump replace...
- '89 Lesabre Oil Temp Light
- 93 LeSabre Front End Scraping
- 1996 LeSabre misses on acceleration
- 1995 LeSabre Custom Unpredictably Shuts Off While Driving
- Question on Traction Light
- Can anyone comment on "Bendix" brand brake pads?
- power windows / power lock issues-- 90 buick lesabre custom
- FRUSTRATED: blower motor resistor location 98 LeSabre
- Type of Gas & door speakers on 94 lesabre
- 1994 Buick Leasbre chuggs when accelerating when hot outside
- 94 Lesabre - Loses fuel when hot, pump wont charge nor engine fire. Please Help!!
- Installing After Market Tack In 1990
- Quit running while hot
- 92 Buick Air temperature is blinking and blower is not working
- Source for 2001 LeSabre carpet?
- 2001 lesabre:shuts down
- 94 buick lesaber custom
- 95 lesabre oil leak?
- Crazy Horn Problem - Listen To This Story & Need Advice Please
- What all can cause a car not to crank? 1997
- ABS problem,94 lesabre
- 94 buick harmonic balncer issues
- DTC P0442
- 92' Lesabre a/c flows thru defrost vents only
- 91 LeSabre Delco Radio
- Ignition module Green Goo
- Replaced 94 Lesabre Brake Rotors and Calipers
- climate control issuse
- break light and break light chime
- 94 lesabre starts, immediately stops
- How to replace rear struts on 95 LeSabre???
- ignition key gets stuck
- 95 Buick LeSabre A/C Clutch Replacement
- '93 Buick Lesaber No start, Not Battery. Please help.
- Low fuel light in '93 w/ indicator lights?
- Buick LeSabre Wont Start In Hot Weather
- Door Panels
- 93 lesabre fuel pump and filter help
- 1992 buick lesabre electical
- 92 Lesabre stalls after 10 minutes
- need some expert help here- Violent shaking / pounding from engine compartment
- Hood Removal
- Can speed wreck cruise control?
- 95 Buick Lesabre error codes
- 1998 LeSabre driver tail light keeps burning out.
- 92 LeSabre stalling, erratic idle
- 97 Lesabre ABS Light On and No ABS
- Air in Rear Brakes
- Power Windows revisited
- '89 Le Sabre - Check Engine light-stalling
- 98 buick 3.8L seriesll
- What is an Adaptive lamp monitor?
- Front Brakes Problem!.. Streering Wheel
- Lesabre Front Bumper
- 97 LeSabre EGR problem
- Odometer Reading
- Hubcap/wheel cover locks
- cooling fan
- Lesabre keeps stalling out...FRUSTRATED
- 2000 LeSabre Service Manual
- Rear turnsignals not working
- 2005 LeSabre Transmission chatters slightly when shifting from 1st to2nd
- what transmissions will mate with and 80's 3.8l v6?
- 92 Lesabre part changed , code and problem still there
- 92 lesabre rear brakes
- 95 LeSabre oil leak
- "Tune-up" or maintenance questions
- What years (if any) LeSabres got the L27 Series III?
- fuel pump issues
- A/C problem
- 93 Lesabre Stalling and no one knows why
- A/C Clutch
- 95 paint code
- 1994 Lesabre Steering Column
- Tail Light Bulb Mystery - Wow!
- Rear Windows De-childproofing
- 95 Buick LeSabre Power Lock Problem
- 94 lesabre tranny
- 87 lesabre problems....need ideas
- 97 only starts on the second try
- ODC II code P-0113 IAT sensor
- Oil Pressure Sender
- 95 LeSabre Hesitates During Heavy Acceleration
- Beware: Cooling System Leak On 1995 LeSabre (3.8)
- Rounding torx bolt on motor mount
- 94 LeSabre SES COdes
- Car just shuts off
- ABS , tracktion off lights are on after i start the car
- leather top
- 1989 LeSabre Intake Manifold Coolant Leak
- May buy 97 LeSabre: will they go 150k to 250k miles?
- 2000 LeSabre Dual Climate Control
- Changing struts on 98 LeSabre
- IAC/TPS Adustment '89 3800 Series
- How difficult is to replace Camshaft Position Sensor
- 91 lasebre idling poorly
- accessing rear door handle in 2000 lesabre
- remote entry doesnt work and a few other problems
