View Full Version : LeSabre
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12 13 14 15
- '97 ALC Questions
- 1996 - electrical issues = battery drain
- 92 lesabre! Please Help Me!!
- EVAP system code 0449
- 95 - Fuse in steering column
- EGR valve 1992 lesabre limited
- 2000 Buick Le Sabre Lights all the time
- 1991 Buick Lesabre Suspension
- What could cause a loud vibrating noise when the ac is on?
- 1997 La Sabre Won't Start - Everything is Dead
- 99 LeSabre turn signal relay location
- 92 le sabre emission test fail NO ppm
- 94 Buick LeSabre No Security Light,Vats Kills engine after start
- help me!!!!!!!!
- OEM Radio Display
- p1665 + p1676 ?
- 92 lesabre coolant gusher
- Do I have ALC??
- Parts Removal
- Blower Motor Resistor Buick Lesabre 1994
- 99 Buick LeSabre ALC system disable
- 1996 Buick Lesabre Keyless remote programming
- Leaky fuel line
- 97 LaSabre Evaporator Replace...
- Locked radio
- Can a MAP Sensor cause idle way to high?
- Maybe too cool?
- any common problems
- how to fix small leak in gas tank
- 94 lesabre fender question
- 84 Buick Lesabre no spark
- Wheel Bearing/Hub Problem? 2001
- another ignition switch question, Please Help!
- Question on horn wiring
- where is the oil filter
- 95 LeSabre Rust Stains In Coolant Recovery Tank
- Intermittent starting problem
- Ingition switch
- Folding Seats?
- headlights and interior light issues
- 2000 lesabre window regulator
- Upgrading Big 3
- Starting issues with 2002 LeSaber warranty running out!
- 88 lesabre 3.8 liter
- Steering Problem
- Cost to Repair
- Keyless Remote
- Anybody heard of two 02 Sensors for the same year?
- Buick Lesabar Misses when climbing hills no engine lite
- Where is the fuse for the horn on a 99 lesabre.
- No Brake Pressure
- 95 LeSabre Transmission Problem
- 2000 Has strong gas smell with fill-up
- Bad BCM??
- Cruise Control
- 97 lesbare whistle/squeal loud at start quiets down after warm up
- "Newbie" needs INFO!
- Replaced Crank and Cam Sensors: Still Dying
- Wondering about torque in cold weather
- Help. Tranny Problems 94 Lesbre. VSS?.
- Removing Damper to Get to Crank and Cam Sensors
- need help identifying a resistor
- LeSabre Door Panel
- Which OBD II diagnostic tool?
- '01 front wheel hub, which design?
- torque converter clutch circuit
- Suspension Improvements?
- 1990 buick lesabre help!!
- Front fender replacement?
- 2000 LaSabre Parking light change?
- 94 Lesabre.. Tried Many Things..nothing is working
- 1994 buick lesabre water pump pulley
- 94 Lesabre Fuel Pressure Regulator
- remove air conditioning pump on a 95 LeSabre
- 95 Buick LeSabre Vats Bypass
- The Damage Done
- 94 Racing at idle
- 1997 LeSabre Trans. Lockout Question
- 98 lesabre engine going into a 94 lesabre
- Location of daytime running light resistor
- LIM Rubber or Plastic?
- 00 Buick Lesabre Window Regulator
- Had My Car Scanned.. And
- Speedometer not working
- 94 fuel pump
- 1994 Lesabre Major Problems!.. Irritating!
- TPS Problem and a few others...
- doors lock when car is put in gear
- Evap code 0440
- 1988 lesabre, where is the ignition fuse
- 92 Lesabre strange problem fix FYI
- 92 Lesabre ipod factory radio direct hook up
- 92 Buick LeSabre Radio help!
- 2002 & 2001 gas gauge failure
- 95 Lesabre Latch on centre armrest
- 93 LeSabre Shakes and Dies After Stopping
- Loking For A Torque Converter And Tranny
- Sometimes car doesn't start, "Diesels" at begining
- Buick 2000 Cruise problem
- 1995 Buick lesabre dies out of the blue
- 1992 lasabre flasher
- "True" Dual Exhaust--A question
- '86 3.8l vin 3 performance & fuel economy poor
- Leather Seats In 97 LeSabre - Good Or Bad?
- Adding "Home-Built" Daytime Running Light Circuitry To 95 LeSabre
- Heated Seats 2000 Lesabre
- 92 Lesabre Limited overheats
- 1994 Buick LeSabre cutting off upon acceleration
- 2002 Buick LeSabre coolant leaks
- False EGR code ???
- 94 Lesabre Hesitating!
- 94 Lesabre Shutting Off!
- Broken Bolts
- Surging,bucking,hesitation All Speeds 1988 3800 T-type
- aftermarket body parts
- 1992 LeSabre - Power Steering Cooler
- Has anyone made their car quieter riding?
- LeSabre 1993
- 2000 intake manifold
- 2000 lesabre auto level
- Series II or Series I 3800 In My 1995 LeSabre?
- '97 Lesbare Alternator Going Bad?
- (1992) Left Cornering Lamp Stays On
- 1996 Buick LeSabre Air Conditioner Problem
- 87 LeSabre IGNITION will not turn to the ON position
- Programming spare remote
- 1993 Buick Lesabre AC Controls, Fixed it!
- Interior Cleaning
- 95 Le Sabre Radio
- Best option to get replacement keyless entry remote on a 97 LeSabre Limited?
- Heater problem 91 LeSabre
- Wire Wheels
- noise transmission
- '94 buick lasabre starts then stop immediately
- '97, intermittent stalling, MAP sensor code
- Shift Solenoid Valve Replacement
- Radio static on '95 lasebre
- 2005 LeSabre limited A/C problem
- 94 still stalling-3.8L Vin L
- harmonic balancer retaining nut size
- 2000 LeSabre Interior Lighting Problem
- 1992 LeSabre Diagnostics
- 86 flywheel vs 87 flywheel, both 3.8
- 1992 buick lesabre timing gear assy
- 00 Lasabre Driving lights
- Any known problems with 2001 Le Sabre?
- how do you read trouble codes on 87 buick lesabres
- radiator drain location 2000 lasabre
- '91 LeSabre service engine light & idle
- 94' Buick Lesabre PCM wires cut, why?
- Anybody tried a CD Manual?
- 2000 lasabre service engine soon light on and will not start
- Doesn't look like a LeSabre to me....
- Error Code P0101 and Idle Air Controller
- Stay with original ac delco plugs
- 97 Buick Lesabre Ltd dragging/hesitanting/stalling
- 93 LeSabre no spark
- 1992 buick lesabre code 41
- 92 Buick Lesabre, thought my alternator died, but now what??? Very strange
- Air Conditioner Moody
- 1995 LeSabre Vibrates/Spudders at 35, 65 MPH
- 98 Lesabre ACC display flashing
- Emergency Brake Extraction
- 97 LeSabre won't start after fixing coolant in cylinder problem
- 1989 LeSabre Massive Coolant Leak at Timing Chain Cover (Front Cover)
- Door speaker removal.
- torque converter clutch control sensor can they cause damage when bad?
- 98 lesabre map sensor oily? why go bad
- Key in-start, nothing. Security light stays on
- 1995 Buick LaSabre - Heater Core Replace
- ABS Wheel Sensor Resistance '97 Lesabre
- What size are the speakers in a 99 Lesabre?
- 93 LeSabre transmission problems
- '92 LeSabre Ignition Switch
- Problem after UIM Replacement
- Light Power Point
- Ding, Ding keeps going after key is removed
- system lean "Bank 1"
- 94 lesabre, hesitation starting and driving
- '95 LeSabre Odd Trans Problem
- 2001 Buick Lesabre brakes
- '98 La Sabre - repair or replace rocker panels?
- 92 Buick Will Only Start Every Other Day
- Temp control sensor 97 lesabre
- Cost of Dynaride Suspension
- Need advice
- How much for a tranny?
- K & N air filter?
- clunking noise going over bumps
- Left Turn Signal
- What do I need, a Cylinder or a Switch?
- Speaker mountings in front door of 94 LeSabre?
- 2000 "chugs" when gas let off
- 93 Buick Lesabre Engine rattle
- No Brakes!
- 93 lesabre tranny problems....help!!!
- 1997 LaSabre Limited, AC fades...
- key fob problem
- Deep Impact
- Need help removing something
- 1995 Buick LeSabre
- S.O.S. Need Help W/Alternater Issue
- Torque converter circuit
- '95 LeSabre problems
- 94 Le Sabre Acting strange...need help
- 97 buick lesabre wont start
- Need help with a seatbelt problem!
- UIM Lawsuit
- Removing sparkplugs
- Where to Buy a Fuel Gauge Sending Unit?
- Need Help finding wool seat covers
- Cost of replacing passkey
- Flippin' rear VC!!!
- Electric Trunk Release Device Problem
- Spoiling my Ride
- Brake/Blinker problems PLEASE ASSIST. 2004 buik lesabre
- How to remove back seat?
- 1993 Fuel Filter
- 1993 LeSabre Seat Swap?
- 98 Custom, Chip in key going bad?
- 2001 Lesabre Rear Brake Noise
- Broke Turn Signal on 98 Custom
- 2000 Buick LeSabre Intermittent start, strange behavior! PLS HELP!
- 1995 Buick Lesabre Limited
- 92 Buick Lesabre Limited. wireless remote control
- 1992 LeSabre Custom Temperature Sending Unit
- How to Troubleshoot Cruise Control on a 1997
- Subwoofer and amplifier installation
- 94 Buick Le'Sabre 3800 engine won't start
- 97 Lesabre dies, will not restart, but will restart later. No codes
- Need to Rehab a 1990 LeSabre Custom
- Full Metal Body
- UIM/LIM assembly
- 2000 Buick whining noise at high speed
- 97 Lesabre(limited) climate controller problem
- 1995 Lesabre Key/Security light help
- UIM Kit Comparison? GM, APN, Dorman
- Problem with the gas gauge
- 1997 Buick Lesabre- Please help
- One more question
- Help...I cant get my wipers off.
- Power Window Motor Issues 1990 Buick LeSabre Custom
- 97 Lesabre whistle /squeal driving me crazy
- 98 LeSabre engine
- HB removal tool for 94 Lesabre 3.8
- OBD question 95 Lesabre
- 98 LeSabre engine code question
- Help, 97 Buick LaSabre water pump replace...
- '89 Lesabre Oil Temp Light
- 93 LeSabre Front End Scraping
