View Full Version : LeSabre
Pages :
1 [ 2]
3 4 5 6 7 8 9 10 11 12 13 14 15 16
- How to change seat belt
- 93 lesabre metal on metal in right turn
- Gas line leak help
- 00 buick lesabre turn signal problem
- My nagging oil leak.....
- '94 Lesabre AC compressor cycles on and off continuously. Won't blow cold
- 1990 right front driveline vibration
- Are Belden Plug Wires, good wires?
- cam position sensor
- 2004 LeSabre Clicking In Dash Engine Whine..Suggestions Pls.
- LeSabre 1993 - Quad Driver Module A error when brakes applied
- 98 Buick Lesabre randomly stops firing
- 98 squeal
- Front motor mount movement?
- Rim leak on Aluminum rims
- Acceleration Problem
- backfirea and caught air filter on fire!!!!
- Cooling System Burp /Bleed
- Front Light Assembly
- 2002 Lesabre Rain Leak
- 1997 LeSabre heater problem
- '94 Intake Leak Question
- 1995 Buick Lesabre: check engine light
- tips on getting gas tank off
- 2002 Wouldn't start and then it did...
- stability system
- 2002 new transmission cost
- License Plate lamps
- 1997 Buick Lesabre randomly Dies (Electric)
- 1997 Buick Le Sabre Wont start when hot
- 2001 Buick starting problem
- 2001 Lesabre Rack-and-Pinion question
- Cruise Control on '97 Lesabre
- 2005 LeSabre
- 2000 lesabre a few problems
- 1987 keeps stalling
- Engine Light Won't Go Out
- 1999 Lesabre UIM/LIM? Problem
- door hinge repair
- 1995 Buick Lesabre fuel pump relay location
- 2001 losing oil
- 97 Lesabre I hear a slight humm when driving
- instant trans shudder
- code p440
- Code p0420
- 90s rear drum leak alts
- swapping cruise controls
- Need advice/insight on what maintenance on a engine swap
- harmonic balancer
- 1990 Buick Lesabre still not running Help
- rear drum brakes help
- 05/03 Leasbre Uneven tire tread ware Question
- Power Steering pump replacement
- error or trouble codes 93 buick lesabre custom
- 2001 LeSabre steering wheel "foam cover"
- oxy sensor code...
- Want to put a trailer hitch, whats a good one?
- Best place to get 100-6YR battery for 2001 Lesabre
- 2000 LeSabre front end shakes when accelerating in a right turn
- oil question need lots of help
- Air Suspension
- Re: Automatic Climate Control Dimmer - Redux
- Bybass hose from LIM to water pump
- Brake problem on 1995 Lesabre Custom
- Re: 2000 buick lasabre starting problem-Redux
- reset service engine soon light
- 2000 Buick with loads of problems.
- 1994 Buick Lesabre 3.8 trans shifts too soon
- Heater core
- p1665 + p1676 ?
- bad compressor or...
- I got hosed....
- Fuel line mount removal???
- Gas leak, need help
- Oil in Intake Manifold?
- Cooling fans operation
- 2001 Buick Lesabre-power window problems
- 92 LeSabre turn signal troubles
- Does a single year have two or three bulb, Tail Lights?
- halfshaft removal questions
- Crack in Dashboard
- Engine has heat, but no heat for jack!
- 2004 Buick lesabre heated seats question
- Transmission Fluid Change
- Headliner cloth dropping
- 97 lesabre custom remote programming
- '92 LeSabre Custom
- 2000 has troouble starting sometimes
- Hints on pulling off plug wires on 2001 LeSabre ?
- 94 Lesabre turns it self off and back on????
- Buick LeSabre 2000 can't start
- 93 Lesabre Cstm - Pass. Side Front Fender Trim
- 3800 cc Misfire Valves or Lifters?
- 95 coil pack
- What's the difference at each end of a instrument cluster
- LeSabre will not start
- 1997 LeSabre Limited
- New Harmonic Bal. no spark
- 92 LeSabre Custom - Third Brake Light
- 1995 Buick Lesabre Starter removal
- what the best way to clean...
- 93 Lesabre Cranks but won't start
- BRAKE Booster- good or bad?
- 95 le sabre knocking noise
- 89 lesabre missing during accel and steady speeds
- oh and one more thing, bumps? in the idle
- AC compressor replacement
- axle nut 93 Lesabre
- have a whole new dilema
- 1995 Buick Lesabre Limited Edition
- 2004 LeSabre Instrument Panel
- 1990 Buick Lesabre wont start
- '97 Lesabre Transmission Slow to Move
- Can't find coolant fan relay-1988 Le Sabre
- 01 Lesabre trans 2-3 hesitation
- UIM story, bad garages...lil funny
- 1993 Driver's door key lock
- 1994 - Lesabre, Fuel pump?
- 84 lesabre v8 coupe value?
- 97' Buick lesabre will start but will not stay running.. HELP ME !!
- 2000 Lesabre Limited-dash controls go crazy
- 93 lesabre won't move
- Temperature incorrect on Comfortemp Display
- Where is the flasher module on a 1999 Lasabre
- 1995 Buick Le Sabre, Lights
- 1995 Buick Le Sabre, sloppy gas pedal
- Coolant goes above max hot line when running...
- Need Help Please!!!
- dead battery 99 lesabre
- LCD temp control display
- 02 Lesabre Alternator gets hot
- Weird Power Steering
- engine knock
- 2004 Buick lesabre speedometer problems
- jon 111
- P0404 and P0405
- 98 buick lesabre upper and lower intake
- tranny shudder fix?
- 1997 lesabre electrical transmission problem
- 90 Lesabre deceleration miss......
- engine temp guage showing lil cool
- does fram xtra guard have drain back valves in them?
- HVAC won't switch to Heat/floor vents?
- need to replace the heater core???
- Lifter noise at cold start up
- Engine vibration at idle
- Idle not steady - moves up/down 150rpm
- Frozen gas lines?! What is there to do?
- Cigarette lighter 2003 Lesabre
- Re: need help with wipers II
- REPOST 2 OF UMI JOB pics inside (maybe)
- tranny problem or engine/tranny mount?
- AC compressor noise
- Blower Mystery... 1992 Lesabre (Getting COLD in ND)
- Strange Vibration - 2002 LeSabre
- You guys or gals are great!
- 1994 Lesabre....question about starting.
- 1994 Lesabre Intake Manifold....Problem Solved!
- Looking at a 95 Lasabre, Need help
- cold start problem
- Radio stays on with key out?
- UIM gasket
- 91 Lesabre stalling, sputtering, hard to start
- 88 Buick LeSabre Starter Replacement
- 1997 Tensioner Adjustment
- Upgrade Radio Advice Please : 1994
- Hard brake pedal and comp code 1406
- coolant loss 1997 popular problem i guess
- Re: Plugs and Wires sounds easy huh?? Take Two
- Door panel leaking - solution
- massive vibration on acceleration and when shifting into overdrive
- Coolant system pressure test?
- Tie-rod ends on '90 Lesabre
- 97 Lesabre headlight / turn signal problem
- 2000 LeSabre help no heat
- Lifter noise (cold) and misfire code 301
- '97 UIM letting go
- Comfortemp Display 95 Buick Lesabre
- Help with 92 LeSabre
- Harsh shift in reverse only when hot
- 98 LeSabre voltage gage variation
- Need Help - 2002 LeSabre
- 97 Lesebre Power Steering Mount Bracket
- No Ext Temp reading??
- Buick LeSabre 98 With 230k Miles on it. got it or not
- Please Help! 96 Park Ave Motor into 97 leSabre
- HVAC code 38 Serial Data failure to PCM
- odd service engine soon light
- high idle on cold start
- Replacing LCDs in HVAC and Radio
- Fuel Pump
- Vacuum sender to Brake Canister
- code 38 on HVAC control
- P0171 Dtc
- Fuel tanks interchangeable???
- 1995 Buick LeSabre Hybrid check engine light on first drive of the day
- MY CAR DIED......can I sue GM for not recalling the UIM?
- Gas pedal hard to push
- 95 LeSabre, DRLs do NOT shut off
- 1997 Lesabre Wiring/Climate Controls
- Rain X Latitude Wipers for 2001 Lesabre
- Just changed fuel sender. Too sensitive!
- Broke the latch on the console
- Rear coil spring question
- ICM testing
- 2002 LeSabre directional issue....
- 2001 lesabre evap canister location
- 2000 Lesabre Trunk leak on right side of trunk
- buick sputtering and now wont start
- 2001 Lesabre Gas Gauge part two
- 2001 - lights flickering every now and then
- service engine soon light- 2002 buick lesabre
- Drain holes in front fenders
- 1989 LeSabre loping
- 93 LeSabre power steering problems
- Drip, Drip, Drip....Follow the Drip!
- 3.8 Series II identification
- '97 Headlights
- abs pump assy
- harmonic balancer
- Struts and shock auto leveling replacement?
- UIM Replacement
- 1995 lesaber air conditioning compressor
- Drilling the firewall for Subs
- Speedometer problem
- 2000 Suspension Question
- Mirror with outside temp want to replace
- 1994 LeSabre Shop Manual
- 1988 V-6 Buick LaSabre Cruise Control Inoperable
- 94 Buick Lesabre 3.8 Upon RPM increase car stumbles and bumbles, no power at all.
- Bang the Drum slowly.......
- 1990 Buick Lesabre won't start
- Rear Brake Rotors
- Shake, rattle, and roll..........
- 92 Buick Electrical Problem
- * * 2000 with no guage lights
- Upper Cylinder head Gasket Repair kit Fel Pro
- Oil Pressure Sensor Location
- Running Rich?
- misfire
- photos of 1992 lesabre 3800 series 1 engine bay
- Need DTC (CODES) Help
- 2001 lesabre
- got to hot, head or intake gasket???
- 98 lesabre hvac codes
- Decoding paper tag on springs
- Timing
- gas leak from fuel filter 97 lesabre
- dash pad seperating
- 94 Lesabre-no start
