View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16
  1. how to check Catalytic Converter
  2. Need Help Heating and Cooling
  3. Rear bumper height
  4. 1986 LeSabre 3.8L - ignition timing
  5. 92 Buick LeSabre 3.8, where is EGR valve?
  6. 1996 Buick Lesabre
  7. 92 lesabre, pkave, vats/passkey
  8. 2000 LeSabre Cruise Control Switch
  9. Retro AC on 86 car
  10. 86 Climate Control Panel
  11. Wiring Diagrams for 86
  12. a/c freezing up
  13. Engine bucking in overdrive
  14. clock light stays on with ignition key off
  15. bad struts on 1998 lesabre
  16. Totaled 1996 Buick Lesabre
  17. leaking brake fluid
  18. '63 LeSabre - 401 need block plugs, where can I get them?
  19. whining from dash
  20. 2001 instrument lights
  21. Obd I
  22. 95 Buick Lesabre Intermittent Start
  23. 2002 Buick LeSabre air cond-heater problem
  24. 1990 Lesabre EGR Valve
  25. 1990 LeSabre
  26. '95 LeSabre Dies Without Warning
  27. 1995 LeSabre - Transaxle / TC Chatter or Rattle
  28. 87-88 lesabre
  29. Problem on windy days
  30. front spring makes noise when terning
  31. Brakes on 92 Buick
  32. Security disconnect, 1997 Buick LeSabre
  33. Engine Stumbles When Coasting
  34. When Shifting into drive...Car Dies!!!
  35. Removed Dash-Won't Start
  36. 2000 lesabre electrical problem
  37. Engine misfires on plug #6
  38. 1995 Lasabre air conditioning
  39. Clattering 85
  40. 1992 Buick LeSabre Won't start * HELP *
  41. 98 Lasabre PLASTIC INTAKE MANIFOLD FAILURE!
  42. installing a t-type gauge cluster in a standard lesabre
  43. 87 Lesabre transmission problems.
  44. What causes a 89 Buick Lesabre EGR Valve to melt?
  45. 2001 LeSabre not auto-shifting in the a.m.
  46. 1985 Seatbelt, Door Ajar and Headlight alarm
  47. 98 Lesabre should i buy?
  48. Radio installation
  49. Need Help From Master Tech.
  50. 86 LeSabre cruise control wires
  51. Hesitates going up hills
  52. 88 Lesabre motor mounts
  53. Cluster Swap
  54. 2001 LeSabre - failed to start in trip
  55. No sound!
  56. 2000 LeSabre Oil leak
  57. clearcoat
  58. 1989 LeSabre no spark HELP
  59. 86 LeSabre Dash removal (new front spks)
  60. radio removal 1999 LeSabre
  61. Airbag Troubles
  62. How to change front struts on a '87 LeSabre?
  63. Transmission Weird.....?
  64. need help "fast" !!
  65. 89 LeSabre poor air flow from vents
  66. Rear Spoiler on 2000 LeSabre
  67. data link connector
  68. New brakes in front sqeaking.
  69. 95 buick uses oil
  70. 90 LeSabre No Injector Signal to Cyl #1
  71. 1993 buick dynaride
  72. gm code site
  73. 94 Buick lesabre abs light blinking-wont come out of park!
  74. heater blower will not turn off ,key off
  75. water everywere
  76. My $600 Oil Change
  77. Turbocharging the LeSabre engine
  78. Buick woes
  79. Rear passenger side window
  80. transmission issues
  81. lesabre compared to park avenue
  82. wipers wont shut off and retract under hood
  83. Fuel Pressure Regulator
  84. 94 Lesabre - Water Leak into Passenger Compartment
  85. Lesabre Hard start after sitting a while!
  86. What fuel injector should I get?
  87. 2000 Lesabre window regulator
  88. Lesabre window track
  89. 94 LeSabre Intermittent Start
  90. 94 Buick Lesabre heater defrost / climate control
  91. 85 LeSabre heater core
  92. Quarter Panels
  93. CODE 34 from computer.
  94. 93 LeSabre Radio Swap......
  95. 94 LeSabre Security Light Problem
  96. 1995 Cruise Control problem
  97. Looking to buy 94 LeSabre Custom but......
  98. Noisey and chattering 3.8
  99. Error code pulled on my car what is it?
  100. Engine "smells" hot
  101. 3800 engine swap 2000 into 1997
  102. 94 BUick Lesabre
  103. 2000 lesabre 3.8....gas mileage is terrible
  104. Engine swap, 2000 3.8 into a 97 LeSabre
  105. Engine Knocks In 1992 LeSabre
  106. horn relay please help
  107. 1989 Lesabre fuse box?
  108. 94 3.8 LaSabre Fuel Starvation
  109. 1978 LeSabre Fuel Line Fire!
  110. 87 buick lesabre running rough and missing
  111. 1991 LeSabre Rear Defroster problem
  112. Fan likes to hang around...
  113. Camshaft sensor magnet
  114. 2000 lesabre....noise near exhaust..windows fogging up
  115. starving for fuel?
  116. 2000 LeSabre rough initial acceleration (new to AF)
  117. Where does gear shift indicator attach to?
  118. Engine swap from one GM to another GM
  119. A/C temp flashing...code -152
  120. 99 Intermitted Defroster Fan
  121. 93 lesabre ltd abs
  122. Gas leaking out exhaust manifold?
  123. 89 LeSabre Starter Location
  124. 91 lesabre heater blows cold air
  125. 91 lesabre engine surges when stopped
  126. Weird Electrical Gremlin?
  127. 1992 Buick LeSaber 3800 Dies in Traffic
  128. I Think I blew my MSC Module. HELP!!
  129. Climate Control Panel starting to die??
  130. is it possible
  131. tons of heating problems
  132. radio removal
  133. LeSabre starting problems
  134. any brake suggestions greatly appreciated
  135. 92 lesabre running bad after warming up, can only drive a little ways
  136. Heater Problems
  137. Coolant Leak???? Help Please
  138. Need '89 Lasabre Front clip interchange info
  139. i'm new and i have questions
  140. Occasional Misfire
  141. brake light/warning stays on
  142. 1993 Lesabre Buildout
  143. 91 Lesabre air conditioning problem
  144. interior lights, 1st post, please help!!
  145. '94 Olds 98 won't start
  146. tranny problem? please help
  147. A/C compressor anybody lost one on a 95
  148. 1997 LeSabre Climate Control shows incorrect temps
  149. 88 LeSabre won't start when cold
  150. '94 Engine randomly quits
  151. Cooling fan relay
  152. WOnt even turn over "HELP"
  153. Any mods done to the Buick ?
  154. Front wheel/cv joint/bearing noise
  155. Coolant system overpressure protection?
  156. 1994 LeSabre Limited VIN check - carfax
  157. Bypass A/C with belt or pully?
  158. 1994 Buick LeSabre won't move until warmed up
  159. Cruise Control Problems
  160. keyless remote programming for 95 leSabre
  161. '86 LeSabre stsrting problems
  162. Remote starter recommendation for '98?
  163. Check Tire Pressure
  164. Engine Mounts
  165. noisy engine
  166. 2000 Buick LeSabre Power Window Controlers
  167. 98 Buick Lesabre Security light on
  168. this pro needs advice
  169. 1990 LeSabre Anti-Theft Reset
  170. 1992 LeSabre Electrical Nightmare
  171. 93 Buick LeSabre cranks but won't start
  172. crank but no start
  173. Opening a hood w/o the hood release.
  174. 92 Buick Lesabre not start
  175. no fan blower
  176. Removing front dash cover...
  177. 89 Lesabre Bumper Removal
  178. LeSabre Padded Dash
  179. 97 buick lesabre no start security problem
  180. Surging blower motor
  181. looking for body parts
  182. 89 LeSabre Intermittently Running Rough, No Codes
  183. Ran Out Of Gas
  184. 90 LeSabre Intermittent Stalling, SEL, Temp Lights
  185. '89 Lababre w/3.8 AC pump noise
  186. 89 Lesabre blower problem
  187. '94 LeSabre with "issues"
  188. Replaceing Motor Mounts
  189. No Spark on a 1986 Buick Lasabre
  190. Lesabre oil leak
  191. Heater wont shut off
  192. is is junk???
  193. code 42
  194. LeSabre Air Vent Controls
  195. Power windows
  196. 00+ junk?
  197. 1989 LeSabre limited radio electrical problems
  198. 1988 buick lesabre won't start
  199. 1992 Buick LeSabre heater is blowing cold air
  200. no air across heater core
  201. 1992 Buick LeSabre Engine Service Light
  202. 1994 LeSabre sounds like washing machine
  203. trunk mounted cd changer
  204. heater not heating
  205. Bulb replacement snags
  206. 1996 Buick LeSabre won't start
  207. Car stalls and cuts off sometimes
  208. 1992 buick lesabre 3800
  209. 94 Lesabre won't start. Someone please help!!
  210. Trouble when Starting - 1997 Buick Lesabre
  211. 96 lesabre SPI codes
  212. Security Light On...
  213. Problems with Cd player :(
  214. 1997 Lesabre - Completely Dead
  215. engine code p0440
  216. 1975 LeSabre Custom
  217. Fuel Pump
  218. Intermitting No Spark problem...
  219. 1994 LeSabre EGR Problem
  220. electrical gremlin
  221. squeeking noise from pullies
  222. heater display
  223. Help with fuel problem.
  224. Key Chime continues after key is removed
  225. I Cannot Live Without A/c
  226. Emissions
  227. Engine REPLACEMENT "VIN L"
  228. powersteering fluid overfill
  229. Lesabre switchplates on doors
  230. whinning noise, suspect the altenator
  231. compass and outside tempature
  232. Service engine light comes on after inclines
  233. [D] and D what is the difference?
  234. 1995 LeSabre Speedometer
  235. GP to LaSabre engine swap?
  236. 1989 Lesabre Noise Driving me Crazy!!
  237. 1992 fluids and brakes
  238. dash rattle?
  239. Fuel Pump and Gas Gauge
  240. Heater/AC Control Panel
  241. Another Question
  242. 1997 Buick Lesabre A/C problem
  243. Electrical all screwed up
  244. Modifications
  245. Manuals
  246. New To Board. And Buick
  247. 2002 buick air suspension growling
  248. I need correct GM part# for Computer
  249. fuel system
  250. Size of Axle Nut
