Buick
> LeSabre
View Full Version :
LeSabre
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
cruise control
Changing Starter on 87 Lesabre
beeping
Dash/steering wheel lights 2004
2002 Keyless Entry Doesn't Work
Wheel Stud + Wobbling Problem
1992 Buick Lesabre keeps stalling
Changed crankshaft position sensor
Thermostat removal
97 LeSabre dash lights wont dim
93 lasabre no spark and with infl reset flashing
surging especially on hills
surge / lack of power
1992 Lesabre won't start when warm
93 LeSabre ; Couple of questions
87 Lesabre Wont Start
1995 buick lesabre heater core leak
ABS/Brake/Traction Lights On
84 LeSabre Q's
Fuel tank
2001 Lesabre Steering Wheel Volume Control
LeSabre Running Rough Under Load
92 Lesabre low idle rattling knock with AC on
Brakes no fluid driver side caliper
Knock sensor for 89 Lesabre?
95 LeSabre Won't Start
Climate control dim on 98 LeSabre
92 Lesabre Limited...locks/trunk opening on their own?
problem with 4 track tape player
fuel injector
94 lesabre cooling fan fuse
Transmission Leak
Terrible thump when accelerating.....
P0101 Code For Buick Park Av. 1996
2001 LeSabre electrical problems.
rough idle speed
Alternator Woes
1990 Buick LaSabre Light Bulb
radiator cooling fans constantly running
91 Lesabre losing coolant
'92 LeSabre MAF
Still runs terrible when hot
Not Starting after it sits
Brake bleed sequence
1997 Buick Lesabre Shuts off when running
Buick Quality
'87 LeSabre - oversized rod bearing still too small
Stalling Problem
'89 LeSabre Problems
Help...Missing link
High and low A/C valves on 1989 LeSabre
CD Player...
Runs terrible when hot
'87 LeSabre - Speedometer sticks when headlights on?
89' window stuck down.
1962 LeSabre
Thinking about buying a 2001
94 LeSabre SES Light
A/C pressure cycling switch
'99 LeSabre Electrical
Low speed fan motor
No A/C
Buick Lesabre Startomg [rpb;e,
94 Lesabre Over Drive quits after 30 min.
94 AC question
94 Lesabre AC switching on/off fast
88 lesabre one coil is not firing
"MAX" A/C
No low speed for blower fan
No low or medium speed on A/C Blower fan
94 buick lesabre
vibration after brake job
Would you reccommend a LeSabre?
92 Roaring....
Help Me Please
1987 lesabre has "hiccup" symptom after crank sensor replacement
'92 lesabre with rear ABS equipped brakes
1986 Buick LeSabre Custom water pump
1994 lasabre cooling fan and a/c controls
1989 lesabre intermitant SES light
2001 lesabre radio removal
1995 LeSabre vibrates at certain speeds
93 Tranny Low Pressure problem
1995 LeSabre A/C Recharge questions
89 LaSaber AC Refridgerant type
The Dash Is Off... But How About The Radio
How do I read OBD-1 codes =16 pin connector
94 Lesabre surging while idleing
Taking apart the dash
FULL trans FLUSH?
2003 lesabre service engine light is on
1995 LeSabre - no high speed on A/C blower fan
94 buick lesabre Shutting Down
ABS acting up
front brake locking up
no reverse
Good Buy Or Good Bye?
94 Lesabre Won't stay running
powersteering
Obd 1 Codes?
Oh crap....dreadful metallic knocking
Custom Parts...
Air condition leak
1994 Climate Control
Lesabre A/C compressor
93 LeSabre Extreme Idle and Tranny Issue
2003 Cabin air filter
lesabre gauge cluster
'96 lesabre no start, no dash warn lts
92 Lesabre won't start hot
89 lesabre
92 buick
Lady needs help w/1997 LeSabre Limited
93 TPS and tranny problems
1986 Buick LeSabre Custom weak spark
00 Le. speed,tach,odo,turn signals no work
do we need adifferential oil change on lesabre 97
1992 LaSabre Electrical problems
1992 LeSabre Dash removal procedures
92 LeSabre ALDL
1997 Lesabre Transmission
94 LeSabre - Shudder upon take-off
97 le sabre no turnover
Aftermarket Tach
92 Lesabre Shuts Off
strut reccomendations
Cigarette lighter
Won't Start
WET Back floor mats?
90 Lesabre Blower motor staying on when key is off
92 LeSabre no HVAC Blower
94 lesabre fuel pump relay location - please help
Massive OIL Leak
PVC valve
Passing gear won't engage!
replacing starter in 1995 LeSabre
ac blowing wierd
cruise control
Help with 2000 LeSabre automatic headlights
Recharging AC in 94 lesabre; HELP!
The LeSabre's REPLACEMENT : Buick "Lucerne"
check engine light
92 LeSabre Misfires/hesitates only when hot
1989 buick lesabre LTD driver door jammed
How can I manually jumpstart A/C compressor bypassing the pressure sensor?
Does This LeSabre look like a good deal?
Replacing ECU/ECM
Catalytic Converter Warranty question..
1994 LeSabre Temperature Cooling Sensor Location???
Spare Tire
LeSabre
Question on 3800 series engine
2000 LeSabre Dashboard change
Computer needeed
89
1986 Lasabre
1998 Lesabre Fuel Line Leaks
95 LeSabre 3800 problem.... help?
Wheel bearings
97 Trunk Leak
High INTAKE AIR TEMP
abs light
* Speedometer Help!!! *
ac compressor
Replacing crank sensor on 92 Lesabre
Air Bag Light
Taillight Cover Assembly
brake light on 82 LeSabre
1986 buick LeSabre Custom no spark on #1 #3#4 #6 and spark on #2 #5 is good
trans fluid/filter change
Help with car engine problem....
1994 Rear View Mirror Replacement
'00 Headers
top speed in 89'
91 LeSabre Fuel Problem
94 Buick won't start--again!, etc.
1991 Buick LeSabre with 3800 Motor
New Starter Still won't start
A/C Goes in and out on my 92
'92 lesabre electrical problems
Leaking Fluid From Muffler
fuel presure regulator on 94 buick lesabre!
Metal clanking sound coming from tranny-flywheel/plate during startup and shutdown.
Location of Fuse Panel for a 88 buick lesabre?
Blocking/Removing EGR
Anyone replaced a exhaust manifold gasket?
vibration from front end while braking
Sulfur Smell-89 Le Sabre
92 lesabre no power to a/c
Speedo Cluster Swap
94 Lesabre Front/Rear Struts Help
1996 Buick Lesabre Wont Start
Headlight Woes
Transmission Solenoids
92 LeSabre won't start when hot...
the a/c blues
Back Windows - Any lower?
Cold Air One Side - Hot Air the Other!
Frozen Wheel Nut
HELP a/c problem
air conditioning
Where online, is best place to buy parts?
security system le sabre 1992
No oil pressure 93 Lasebre
fuel gauge
harmonic balancer 92 buick lesabre
changing water pump
95 Lesabre 3800 engine problem
Mitchell OnDemand 5 DVD
94 Le Sabre Tranny Problem
1995 LeSabre Custom trouble starting
94 Lesabre Tranny problem
Wants to stall during cold start-up
Paint
Motor Mounts
'89 LeSabre Speakers
2 separate problems with my 92 lesabre
3800 serpentine belt
buick TPS problems
need upholstery
spark plugs
94 LeSabre Air Conditioning could be dying
1995 air conditioning problem
old car
95 Lesabre Custom won't start
TPS - Hesitation problem - 1994 Lesabre Buick
New Owner... Big Plans !!!
Speaker Sizes?
Meineke broke my air vent damper
95 LeSabre Randomly Stalls
headlights
Lesabre's Transmission High Gear Doesn't Shift
Transmission High Gear Does's Shif.
i need help
2000 LeSabre Platinum
headlights turn on by themselves
Squeak/ squeal
roof falling off - '89 lesabre.
Spark Plugs
1985 buick lesabre collector edition door adjustment
Problem with my 92 LeSabre dying
Lights Stay On - '92
Fuel tank Installation "HELP"
Lights flicker on '02
intake manifold leak, possible lifter noise too
1996 door latch assembly
Is it possible to replace a tranny from a 1989 Lesabre with a 1992 Lesabre?
Changiing Fluids
Changiing Fluids
1987 Water Pump
