View Full Version : LeSabre
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 [ 14]
15 16
- What to do if good Remote won't program
- stalled all day,ran perfect tonight/?
- stalls in gear at low rpm's
- Help! My Headlights Wont Go Off!!
- 1999 Buick Lesabre Transmission Shudder
- 1993 Lesabre stuck in panic mode????
- 97 3.8 vin k Plastic intake leaked, cylinders full of water.
- 1990 Buick LeSabre Limited
- 97 AC computer location
- 2000 LeSabre sputters when warmed up
- 85 LeSabre Trouble codes
- Rear signal bulbs on 1991 LeSabre
- How do you test for a bad CV Joint versus Balljoint?
- 85 brake lights not working
- Not a DIN and a Half and NOT Double DIN
- loud crackling in speaker
- Strange Surge/Hesitation
- 1992 With Poor Brakes
- service engine light
- CV joint again
- 1988 to 1986 grille
- right front signal light is flashin fast
- 94 LeSabre Transmission Problem
- 88 lesabre speed sensor location.
- "Security" light
- 1995 door indicator doesn't go off
- 1989 Blower motor problems
- 92-lesabre-water getting inside
- 1992 lesabre hood
- 97 Power Steering Leak
- Transmission clunk
- 89 LeSabre transmission p/n
- Conflicting Numbers of what Keyless will work
- cv boot
- Replacable Parts for LeSabre
- 1996 LeSabre No Parking Lights, No Dash Lights after Bulldog remote starter installed
- 88 3.8 running rough( timing?)
- Security Light
- 95 LeSabre - wiring harness
- 2001 LeSabre-Replace standard A/C control with Climate Control?
- Power window regulator problems
- Vacuum modulated AC?
- A/C Clutch Relay
- 92-wet road fun-now tach gone
- Adding rear anti-sway bar 2000 Lesabre
- Knock Sensors
- PO440 code
- Climate control reset
- I have a ding, ding, ding question
- 92 Lesabre-need Some Good Advice!
- '97 LeSabre audio deck compatability
- ABS Light
- 1992 LESABRE-DASH LIGHTS DONT WORK-Need Suggestions
- Serpentine belt tensioner - tough repair job!
- Transmission hesitates 1992 Buick Le Sabre
- Vinyl Roof Leaking
- 88 Buick lesabre transmission slip
- Water in Taillights
- Newbie Radio question
- 89 Lesabre interior lights
- 1989 LeSabre T-Type maintaining RPM problem
- Electric window panel
- pvc valve location
- 92 buick-service engine
- 1997 Buick Lesabre dead (then alive for a while)
- 97 Can't find power steering reservoir...
- 94 LeSabre dies won't restart easily
- do L vin 3.8 motors melt plastic intakes ?
- '92 LeSabre AC Question
- no power to ignition module
- Front end wobble
- 95 Lesabre - Harmonic Balancer
- trunk release for 97
- What years/models can I get a front right fender for my 91?
- '95 Buick Lesabre - Water Pump Bolts - Help!
- feel air coming out of defrost vents only
- 97 Headlight cornering lamp question
- 1997 lesabre speedometer problem
- 97 LeSabre w/ VERY high oil pressure after installing new engine
- 93 lesabre heater fan problem
- Phantom Stalling after short stop
- Service Engine Soon Light
- 93 LeSabre losing power
- 87 Lesabre stalls
- 97 LeSabre Transmission Hunting
- 88-91 Lesabre owners, could you look at something under the hood??
- 96 lesabre wont start
- what are trouble spots on 98 lesabre? might buy one
- 92 Lesabre Left rear transmission mount
- 91 Lesabre Parking Brake woes
- 91 Lesabre A/C recharge question
- dash
- 2002 buick lasabre remote
- radio installation and codes required
- 89 lesabre performance?
- Child Locks
- 1999 LeSabre shudders
- remote starter
- Best Scan Tool
- a/c stops blowing while accelerating
- 92 Buick LeSabre-Headlights Won't Come One-Please Help!
- Need to ask dumb ?
- Noise on engine-AC clutch??? Pleeeease help!
- 86 Lesabre heater display lights blink/heater doesn't work
- Spongey brakes on 2000 LeSabre
- 2001 LeSabre Noise upon start up
- Which refrigerant?
- '98 lesabre, RPM limiter, weight reduction
- keyless entry installation for '97 Buick Lesabre custom
- 91 Lesabre Driver Side Door Won't Open From Outside
- AM/FM /CD Player
- 92 Lesabre - Code 26 No Cruise/No High Mount Stop light
- 97 lesabre dash
- 97 Buick Lesabre Instrament Cluster
- Heater Air Conditioning Control Panel 1993 Buick LeSabre
- 92 lesabre speedometer
- 1995 LeSabre Cruise Control
- 90 map sensor location (help)
- How to replace rear shocks on 95 LeSabre???
- 2001 lesabre
- 1989 LeSabre radio problem
- stalling '87 lesabre
- More strange '94 error code behavior
- 1989 Buick LeSabre Cold Start Problem
- 99 lesabre exhaust
- Car radio
- 92 Lesabre starts sometimes
- Driver's seat too short in '94
- Taillights 1996 Buick LeSabre
- 92 LeSabre water pump (?) problem
- 89 lesabre parts car
- Transmission removal problems
- No Cruise Control when running Wipers
- Turn Sinal Flasher 1994 LeSabre
- i changed steering colum and now wont start
- Which Tranny
- Lesabre Belts
- changing power steering fluid, 94 LeSabre
- Mods and other fun stuff
- 92 LeSabre New here
- My '92 Creaks and Wobbles
- Engine Removal
- Dash alignment with door
- 1996 Lesabre Serpentine Belt Replacment
- '90 3.8L shakes wildly under throttle pressure?
- Auto Headlamps 97 Lesabre
- also new to buicks and this forum
- Gauge Problems
- Noise in blower in 2000 LeSabre, remove dashboard.
- OBD1 w/OBD2 connector on 94 LeSabre
- 93 buick lesabre serpentine belt
- Air/heating venting problem
- 87 LeSabre - Idles very fast
- 97' fuel gauge problem
- where is evaporator plug? 2000 lesabre
- 95 LeSabre Speedometer Fans Gas Gauge Problems
- Door Glass Plastic Guide
- 2004 LeSabre Vibration Problem
- 88 lesabre 3.8 need some advice
- Check Engine And Temp Light Flashing
- Air-Conditioning Problem...
- 95 Horn Problems--HELP--
- Oil Change
- tire pressure for '95 buick
- CD player/changer
- Stupid Busted Ignition Switch!
- 1984 buick lesabre limited
- 90 LeSabre speaker change
- 95 radio into 93 harness
- 94 LeSabre's
- Vehicle will not start
- I Cannot Keep My Delco Battery From Leaking Acid Under My Seat???
- Oxygen Sensors
- 98 LaSabre Runs Away
- "93 Lesabre fuel filter location????
- 1994 LeSabre engine running rough, accelleration problems
- '84 rim problems
- 92' Lesabre slow accel in drive..
- 94' Lesabre rough idle, loss of acceleration...
- I Found out what my noise was
- 1992 LeSabre Computer Malfunction?
- LeSabre
- 93 lesabre won't crank
- fenders
- Ughhhh Here we go again
- 85 LeSabre coolant, smoke
- EGR Valve
- '94 Strange error code behavior
- Have a new Question
- '92 LeSabre A/C-heater controls
- Poor Air Flow
- 92 Buick LeSabre Electrical Problem
- 1996 Buick Lesabre
- Problems? Of course!
- Rattling near muffler when electrics on
- Have a strange question
- 2004 frt seat rebound at stops
- Heating and A/C problems on my '97 Lesabre Limited
- 92 Lasabre Starter interupt relay - where is it!!
- Spark Plugs-Brand & type
- 2001 LeSabre rear door panel removal
- 1996 Lesabre Bucking/stumble in overdrive
- Obnoxious Front End/LH/Steering Clunk 2000 LeSabre, How Loud Might A Bad CV Joint Be?
- 00 LeSabre Drivers Mirror Shakes At Highway Speeds
- 95 Lesabre Data Link Connector Wired Wrong
- A/c and electric windows still working after key is turned off.
- I need 1999 Healight info
- 1990 LeSabre with possible fuel problem...
- Code 26 QDM?
- 94 LeSabre Questions
- Scan tool for 1987 Lesabre (and others too)
- Hvac Blower Motor 97 Lesabre Limited
- Tool to remove door panel
- 1995 smokes, compression good ?
- 1975 buick lesabre important question
- 88 LeSabre headliner removal
- HVAC Blower Motor flaky
- 94 Lesabre acts like its running out of gas
- Charcoal Canister?
- Heat vs. Air conditioning problem
- Remote control front door locks won't open
- Crank Shaft Pulley Bolt
- 92 Lesabre Code 58 Fuel Enable problem
- radio,clock,horn
- Ignition Problem
- Leaking power steering fluid
- 1992 Lesabre fuel filter location
- 1994 Buick Lesabre battery won't keep a charge
- defective moisture sensor in windshield
- 97 LeSabre Climate Control Face is too dim
- 1995 Buick Cruise Control
- noisy th440 transmission
- Air Suspension problems
- A/C Question
- ENGINE STUMBLES WHEN COASTING (update)
- 91 LeSabre Door panel removal
- Interior lights will not go out
- Please help before warranty on 2001 expires!
- 89 lesabre ttype radio electrical problem and a/c problems
- 1994 Buick Lesabre - smoke
- 89 lesabre loses all power
- Bug/Hood Deflector
- A/C problem
- A/C conversion from R12 to R134a
- cruise module location 89 Park avenue
- GM plastic intake coolant leak on 3.8L
- HVAC blend door not working
- -=WANTED=- delco cd player for 1994 lesabre
- Power Window Problem
