View Full Version : LeSabre
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 [ 13]
14 15 16
- 94 Headlight Adjustment?
- HELP my 94 - Won't START, dash says SECURITY, chip key ? broken ignition cylinder ?
- 97 Buick Water Pump Replacement Hitch
- front signal bulb replacement
- Problems With First Car
- light smoke from dash 91 lesabre
- No first gear when 15 degrees or colder
- Engine vibration
- White Smoke
- 1992 lesabre flasher location
- 95 Le Sabre
- Transmission
- 94 LeSabre heater control
- Heater Temp Swings
- heater mind of its own
- 4T60 Transmission 'bump' when going 3 -> 4
- belts,tranny
- 94 LeSabre Starting Problem
- Intermittant headlamps
- 1987 Interior Lights Not Working???
- 1994 LeSaber will not turn over.
- Cold Starts
- blower motor
- cold weather + engine light
- Heater temp swings
- brake lines on 1989 lesabre limited
- Great Deals Online
- 1998 LeSabre Custom belt tensioner
- 3.8 buick park ave buick wanting to die
- Dianogstics...
- 1994 lasabre suspension
- Check engine ??
- Turbonator, anyone?
- Oil Pump Will Not Prime
- electrical
- 1990 LeSabre-Too SLOW!!!
- Weird Shaking
- Idles high and low in freezing temps
- Radiator Reverse Flush
- High oil pressure guage
- 85 lesabre engine problems.
- new cd player
- CV Axle removal Problem
- Anyone? - 2000 LeSabre Radio
- 95' Buick downshift problem
- '93 Buick LeSabre problem - interior lights stay on
- 1990 Lesabre wont even turn over
- wheel noise & ABS light
- general tuneup
- 4T60E GM transmission related advice
- help, is it possible
- problem with 85 lesabre limited
- brakes.
- The Living Dead
- can i turbo it with grand natinal turbo?
- Mysterious Box
- Tranny shifting question
- Gear shift problems
- 01 LeSabre stranded wife
- Windshield Washer Pump
- parting out 90 le sabre
- 87 lesabre for repair
- stupid question
- 1992 problem with lights
- 2000 Lesabre Climate Control
- Just need a few pointers.
- 92 LeSabre Engine Mounts
- fuel or ignition??
- '94 vs '95 interchangable parts??
- 1987 Lesabre with no spark
- HELP: body /service manuals
- bleeding brakes on an 88
- blinkers dont work!
- '94 LeSabre Serp. Belt MYSTERY
- 94 Lesabre Problem.. code for bad pcm
- '94 LeSabre water pump changeout
- paint flaking off my 93 lesabre limited
- 96 buick lesabre losing voltage
- Removing door panel on 89 Lesabre??
- Brake question '90 LeSabre
- Need Advice About 02 Sensor
- 2000 lasabre- 3.8L v-6 temps
- 94 lesabre, random cylinder miss
- Can't open door on 89 Lesabre
- 88 Lesabre won't start, Fuel problem
- 2000 LeSabre Radio Antenna Connector
- Roaring noise when ignition is turned on
- 2003 Buick Lesabre
- 1988 Buick LeSabre (Lost it's get up and go)
- security light, infl. rest light
- 1994 Buick Lesabre Misdiagnosis..advice?
- roar that I can't identify
- exhaust specs
- Keyless entry transplant help (92 => 94)
- 1990 LeSabre fuel lines
- 1987 buick lesabre cam sensor and interruptor magnet
- Windshield wipers jitter
- 1994 Buick starting problem $$$ and not fixed!
- Supercharged Lesabre
- What is the interval for tranny fluid/filter change for a 98 Lesabre
- 98 Lesabre engine idle not steady on occasion
- 98 Power steering pump issue
- plastic coolant connector braking twice
- 1995/2000 Radio Harness Wiring
- Supercharger in '97 LeSabre. New Computer?
- Replacement Tires for 2000 Lesabre Custom
- Terrible Noise
- lesabre dash lights
- buick serpentine belt
- Blinkers
- 95 Buick LeSabre Transmission Problem
- 1999 buick lasabre fuel filter location
- HELP!95 sabre 3.8 big prob
- 1990 LeSabre Steering Problem
- 88 - where is the crankshaft and cam sensors?
- Just installed Ken-Co intake manifold repair kit
- 1995 LeSabre ABS
- Picture of Belt Route
- 88 lesabre wont start
- what that migh be ECM,BCM,alternator
- How do you post attachments/pictures
- 88 Lesabre "C" engine code reading?
- Intereror lights blink at night-1997
- Voltage problem only at start
- HELP--'91 lesabre fuel filter rusted on!!
- Loud knock after vacuum hose change
- 88 Lesabre, hood won't open
- Car loses power when ac turned on..can someone help?
- oil filter seal blows at start
- Speedometer
- 1995 Buick LaSabre oil light
- 93 buick has hesitation when going uphill
- master cylinder leak
- Cold Start Up Noise for 60 seconds
- After Market Gauges
- '91 Buick cat check?
- Gauges
- 2000 a/c problem
- need help with cruise control and window regulator
- headers
- 1999 Lesabre overhead light
- 1984 "Oil/Choke" Problem!!!!
- 87 LeSabre Door Trim Molding Removal
- 97 Lesabre with surging problem
- just got a lesabre
- hvac codes and relay update
- 170 K on the engine
- Heat Shields on Exhaust Manifold Loose and Rattling
- 92 LeSabre Headlights wont turn off
- O2 Sensor
- '91 Buick Les LTD stumbling/stalling
- 87 LeSabre Power Lock Relay
- Tail Lights...
- no spark 92 lasabre
- Help - 97 Buick LeSabre transmission surge
- '95 Buick Cylinder 5 keeps misfiring
- GM Dealer Uses KREX GRAPHITE Additive In My 2000 LeSabre???
- $550-$600 to change lights in Dash.
- 1997 Buick LeSabre S-Belt R&R
- 94 Lesabre starts then stops; crank sensor?
- 1985 Lesabre Collectors Edition
- 91 LeSabre runs rough @ 55 mph
- relay and codes
- Front wheel bearing
- 94' engine shaking
- Oxygen Sensors: Is it really worth it?
- Radio removal.
- Right door probs
- 20 Minute CD limit
- 95 LeSabre with a 4T60-E Tranny with problems
- 92 Headlight/Battery Problem
- '89 LeSabre with a vibration problem stumper
- How to determine bad water pump
- Opinion: Water Pump Bolts Torque Spec
- getiing door panel off a "93"
- supercharge my 98 lesabre
- Blower Motor HELP PLEASE!!!
- 98 Buick Lesabre squeaking noise when hot
- Power Seat "UP" doesn't work...
- 97 lesabre tail lights out
- 1995 Le Sabre rear passenger window install!!!!?????
- Courtesy lights
- 91 LeSabre car starts only when cool
- 1995 LeSabre Electrical Problem
- 87 Lesabre runs rough, stalls, EGR code
- New Info: 1995 non-OBD-II 16-pin
- Big Favor: 1995 LeSabre Factory Service Manual
- 1995 Buick Air Cond. Vents
- Tranny oil/filter change ?
- lesabre relay diagram
- 91 Lesabre dies
- 1995 16-pin Info / Cry for Air Bag help
- 89 Lesabre won't start when damp
- 1992 lesabre blower problem
- Checking Codes - '94 model
- 97-What/Whare in the car is the thing that gets the signal from keyless remote?
- So very quiet
- 1975 Buick LeSabre
- 2000 Lesabre Starting Problem
- 1990 Lesabre power seat problem
- Can't get the headlights off!!
- burned out blinker bulb
- Misfire 92 lesabre
- Wheel Bearing Problem
- EGR Solinoid
- 1988 buick lesabre ignition problem...please help!
- 2000 Buick LeSabre Body Electrical Problem
- EGR valve
- 97 LeSabre lost drive on highway!!
- '95 LeSabre With P0123 Code - Info Only
- DRLs and radio
- Strange Gummy Sealant - 2000 Door Panel
- 90 lasabre engine stumble at idle
- 90 lasabre has 4 slow power windows
- 1993 lesabre, shuts off & smoking!!!!!! Help!
- Changing brake pads
- Double Shift
- MPG Calculation
- 2003 keyless remote
- Intermittent DTC 63 Cruise Control SPS Low
- Odd Noise
- 92 LeSabre Leaking Brake Fluid
- Service Manual
- tips on replacing Master Cylinder anyone 92?
- Idiot light question on my "96" Lesabre
- Shake
- 92 buick lesabre custom is vibrating at 1500 to 2500 rpms
- 1992 LaSabre Lighting Problem
- How to add a tach to my 91 Lesabre
- 1988 Buick Lesabre With a few Problems
- 1996 Strange engine noise
- rear brakes in my 98 buick lesabre ltd. banging
- 98 Le Saber Boggs out at full throttle
- Swapping rear view mirror in a 2004 LeSabre
- 92 Lesabre still dies while driving
- 92 Lesabre break pedal sinks to the floor
- Battery Drain 1995 Lesabre
- noise and shudder
- brakes
- serpintine belt
- Dieing While Driving
- Selling my LeSabre, what's a good asking price?
- ABS Warning Light (1995 LeSabre)
- How to replace the belt tensioner idler/pulley on '89 Lesabre
- Cross 1 & 5 wires to start car
- 1992 LeSabre Heater A/C malfunction
- 86 buicl lesabre starter problems
- 3rd is OD, OD is Nutrul, Nutrol is Reverse
