Our Community is 705,000 Strong. Join Us.
View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. 01 turn signal flasher?
  2. Speedometer problem (2000)
  3. Turn signal lever
  4. car wont start
  5. car wont start
  6. 98 lesabre intake plenum safe removal
  7. 89 le sabre
  8. 1990 (or possibly 1991) LeSabre loud metal clunking noise
  9. Shocks and Struts? NOSIE?
  10. Harmonic Balancer - NO SCREWS, 3 SLOTS - HELP!
  11. Update on BCM - Interior Lights Blinking, I can't believe this!!!!!
  12. LeSabre code PO 440
  13. 1986 Lesabre Estate Wagon Not Charging
  14. Heater/AC control module???
  15. 92 LeSabre noisy rear end
  16. steering fluid leak
  17. belt tensioner +coolant lines removal on a 99
  18. 79 Secondary Coil
  19. gas pedal sticking
  20. '87 - Inst Panel problems when dimmer is on
  21. Strange Ticking Noise, Goes and Comes
  22. 94 LeSabre
  23. 94 LeSabre
  24. oil selection
  25. Autozone lists recall but can't get the info
  26. Door Poppers
  27. 00 lesabre will not start
  28. One more stalled Buick...
  29. Ken-co repair kit?
  30. Heal-A-Seal Gasket Repair
  31. Buicks Hate Bosch!
  32. '92 tranny: what is this sound?
  33. Has anyone ordered from oehq.com?
  34. Replacing struts..Monro, Gabriel
  35. 91 lesabre starts then turns off after 2 seconds
  36. Speed-related noise in 2001 Buick
  37. Replace coil packs or not???
  38. need help with wipers
  39. 95 fit a 96?
  40. keep it, or bail?
  41. Need Help From the PROS!!!
  42. Door parts
  43. '97 3800 engine squeal issue
  44. can't shift
  45. 91 LeSabre cuts out after warm up
  46. 1996 Buick Lesabre engine
  47. 1996 Buick Lesabre Blown Head Gasket
  48. Pimpin' My Buick
  49. DTC's on 95 Chevy Tahoe
  50. P 0507 Engine Code/intake replacement
  51. Fuel gauge acts weird
  52. air ride
  53. windsheild wipers wont shut off
  54. 1990 Buick LeSabre cold starting problem
  55. 1990 Lasabre inner door panel
  56. Are Radiatos a "Throw a way item" now?
  57. heater and a/c blower quit working
  58. heater and a/c blower quit working
  59. 97 lasabre fuel pump amperage
  60. grinding noise...
  61. Leaking fluids overnight????? help!@!
  62. 94 LeSabre- starts, shuts off right away
  63. power seat
  64. 2001-Tranny/Computer Dying?
  65. 91 rear brakes
  66. performance
  67. new to forum
  68. Dex-Cool and Sludge
  69. 1994 Buick Lesabre Custom
  70. 1986 Buick LeSabre
  71. LeSabre 94 dies sometimes
  72. 1994 Buick Lesabre Custom Interchangable Parts
  73. Clean oil in pistons 5 & 6
  74. 97 buick door locking system
  75. 89 century runs rich after warmed up(no response on century forum)
  76. '87 LeSabre - Problems shifting 2nd->3rd when cold
  77. Drive Ratio from: 2.95 to 3.05 ?
  78. 2000 lesabre
  79. Starter location???
  80. 1990 into a 1986 3.8
  81. '00 "garage lurch" need help PLEASE!!
  82. Air vent buttons troubles
  83. Buick Lesabre custom
  84. 2001 Buick Lesabre Delco Theftlock Help!
  85. abs problems
  86. 98 lesabre limited...pcv location
  87. '87 - No Cruise Control
  88. thermistat position
  89. 92 lesabre, no air flow
  90. Can anybody tell me how to take the grill off my 99 lesabre??
  91. Slow Weak Window Motors on '90 Lesabre
  92. 97 Lesaber Belt
  93. what the bloody hell...My windshield wipers will NOT shut off!!
  94. Trouble codes: P0121, P0300, P1406
  95. Drivers Rear door, no power lock or window
  96. 1997 Buick LeSabre Digital Climate Control
  97. heater
  98. 1993 LeSabre Custom-several issues
  99. 96 Buick LeSabre Climate Control Trouble
  100. Voltage Problem
  101. 1995 LeSabre Custom Right Turn Vibration (Read In)
  102. 98 Buick Lesabre running rough and now not starting!
  103. 2000 LeSabre- no power to diagnostic port
  104. 1995 Buick LeSabre Electrical Problems
  105. 1994 Buick Lesabre won't start
  106. Windshield washer pump/rear side marker
  107. Which scanner to buy?
  108. Programing a Body Control Module
  109. Good parts needed at a good price
  110. 92 buick makes a dinging sound and break light stays on
  111. 98 le sabre lowering springs/better suspension
  112. Aircon or computer problem or ?
  113. Blowing white smoke
  114. 95 lesabre Growel :disappoin
  115. 1997 LaSabre radio doesn't work after battery disconnected - not anti theft problem.
  116. Power Window Problem
  117. PLENUM Intake Failure, What kind of fluid did you use?
  118. Difficulty Starting (Episode 2)
  119. T-Type questions
  120. 3800 C - Misses When Hot
  121. rims
  122. no fuel to injector rail
  123. wanna do an engine swap
  124. engine code
  125. Broken/Warped Plenum's all over the place
  126. blocking off egr valve ? any problems
  127. Aftermarket CD Player
  128. 95 Lasaber altenator output cuts in and out
  129. 93 Lesabre Transmission Replacement
  130. Drivers side floor wet
  131. Muffler
  132. 94 Lesabre - Code 1650 QDM2 failure, weird problems...
  133. 94 Lesabre - how to remove back seat?
  134. 97 No Park/tail Lites
  135. pipes
  136. 00 lesabre
  137. Scanner says, "Intermittent Misfire" What kind of crap is this?
  138. 95 Lesabre overdrive shudder/vibration
  139. 1990 lesabre heater problems emergency brake light
  140. Replace Power Steering Cooler
  141. transmitter
  142. 92 lesabre transmission no 3rd gear
  143. which vin motors leak plastic intake ?
  144. Weak Fuel PUMP - Confirmation?
  145. My 2002 Lesabre is a piece of crap
  146. 1988 LeSabre Limited with climate control - Relay or Blower Control Module
  147. 98 limited tranny stop working
  148. 2000 leasbre
  149. turn signal lever wiring
  150. 2000 LeSabre electrical system goes nuts!
  151. 2000 lesabre
  152. '87 LeSabre - absolutely horrible milage
  153. 00 lesabre
  154. 1992 buick lesabre program fob
  155. scan tool
  156. 2000 lesabre
  157. 92 LeSabre-engine stops while driving
  158. 1998 starting problem
  159. washer pump electrical
  160. Difficulty Starting
  161. 89 le sabre fuel system problems
  162. New Rims
  163. 91 LeSabre Code 41 Keeps Coming Back
  164. 92 LeSabre instrument cluster compatibility, general questions
  165. cover for defroster vent
  166. 94 LeSabre - Going bonkers?
  167. strange behavior from 92 lesabre -fuel filter or computer?
  168. 1996 LeSabre Water Pump
  169. Is this normal
  170. Lesabre wont start
  171. 00 LeSabre ABS/front hub question
  172. Rough starting w/loss of speedometer
  173. 1995 coil packs and Mod
  174. 2001 lesabre rear brake pad replacement
  175. Buick Coil Pack test
  176. Dome Kight Hell
  177. 01 Buick La Sabre Fuel Level Sensor
  178. Replacing AC compressor
  179. 01 La Sabre Fuel Sensor
  180. 1995 buick lesabre struts
  181. 2002 Won't start on first try!
  182. fuel filter?? 97 lesabre 3.8
  183. Starting Issues - Please Help
  184. 93 Lesabre No heat
  185. 2001 Limited transmission woes
  186. Buick 350 to Chevy 350
  187. 1990 LeSabre electrical problem
  188. 2000 Lesabre battery location
  189. I'd call it a fludder in the front right.
  190. 97 smelling gas after driving found problem
  191. If I take out a fuse, will I get a check engin light?
  192. Lesabre gone crazy
  193. Headliner removal/dropping
  194. front end vibration
  195. 2003 LeSabre ABS/Traction Off/Brake lights remain on
  196. Headlights not working
  197. 1993 LeSabre - Electrical Problem
  198. 2004 lesabre airbags
  199. 1994 LeSabre No Spark
  200. Engine Vibration
  201. 2nd CV axle in 2 months
  202. Head Lights Won't Come On
  203. Plug wires
  204. abs brake problem
  205. Custom Wind Deflectors
  206. smelly exhaust
  207. Passenger gets maximum heat all the time
  208. Fuse box location
  209. Question about brakes/hesitation
  210. 2003 lasabre tranny problem
  211. Millage with your 3800
  212. What Are These Holes In Dashboard
  213. Climate Control
  214. Keyless Entry
  215. Troubleshooting Heated Seat
  216. weird problem w/ my '95 lesabre
  217. Auto Leveling
  218. What is "Twilight Sentenial"?
  219. Help Need Louder Muffler
  220. buick lesabre
  221. HELP with decision
  222. how to change 95 lesaber heater hoses ?
  223. Anyone have advice / guidance on how to change a water pump (91 Lesabre)
  224. '97 LeSabre miss
  225. 89 lesabre- front end shimmy
  226. What is this "Reset Oil Button" for??
  227. Motor Oil
  228. Infl.Rest. light Stays On
  229. 96 Buick LeSabre trouble starting
  230. help? 1989 buick lesabre limited
  231. 91 Lesabre won't start
  232. 90 28,000 miles backfires on hard accell
  233. Custom SG
  234. My First Buick
  235. Trunk Leaking
  236. resistor chip keys
  237. 92 LeSabre A/C auto activation Logic
  238. 94 lesabre idling problems
  239. '93 Lesabre hesitates in the begining
  240. 1998 to 2000 Lesabre, Any known Chronic problems ?
  241. Tune UP Time?? or Something Else?
  242. Key in / headlights on chime
  243. '96 lesabre turbo/supercharger
  244. new exhaust/lighten the car
  245. 2001 lesabre rear window operation
  246. Type of Battery(s?) for LeSabre FOB?
  247. What,Where is the DLC connector?
  248. 90 Buick Lesabre - Starting problems
  249. 2000 Buick Lesabre Custom NO Heat Heater Core fine
  250. 88 Lesabre Parts
