View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16
  1. '87 LeSabre - Speedometer sticks when headlights on?
  2. 89' window stuck down.
  3. 1962 LeSabre
  4. Thinking about buying a 2001
  5. 94 LeSabre SES Light
  6. A/C pressure cycling switch
  7. '99 LeSabre Electrical
  8. Low speed fan motor
  9. No A/C
  10. Buick Lesabre Startomg [rpb;e,
  11. 94 Lesabre Over Drive quits after 30 min.
  12. 94 AC question
  13. 94 Lesabre AC switching on/off fast
  14. 88 lesabre one coil is not firing
  15. "MAX" A/C
  16. No low speed for blower fan
  17. No low or medium speed on A/C Blower fan
  18. 94 buick lesabre
  19. vibration after brake job
  20. Would you reccommend a LeSabre?
  21. 92 Roaring....
  22. Help Me Please
  23. 1987 lesabre has "hiccup" symptom after crank sensor replacement
  24. '92 lesabre with rear ABS equipped brakes
  25. 1986 Buick LeSabre Custom water pump
  26. 1994 lasabre cooling fan and a/c controls
  27. 1989 lesabre intermitant SES light
  28. 2001 lesabre radio removal
  29. 1995 LeSabre vibrates at certain speeds
  30. 93 Tranny Low Pressure problem
  31. 1995 LeSabre A/C Recharge questions
  32. 89 LaSaber AC Refridgerant type
  33. The Dash Is Off... But How About The Radio
  34. How do I read OBD-1 codes =16 pin connector
  35. 94 Lesabre surging while idleing
  36. Taking apart the dash
  37. FULL trans FLUSH?
  38. 2003 lesabre service engine light is on
  39. 1995 LeSabre - no high speed on A/C blower fan
  40. 94 buick lesabre Shutting Down
  41. ABS acting up
  42. front brake locking up
  43. no reverse
  44. Good Buy Or Good Bye?
  45. 94 Lesabre Won't stay running
  46. powersteering
  47. Obd 1 Codes?
  48. Oh crap....dreadful metallic knocking
  49. Custom Parts...
  50. Air condition leak
  51. 1994 Climate Control
  52. Lesabre A/C compressor
  53. 93 LeSabre Extreme Idle and Tranny Issue
  54. 2003 Cabin air filter
  55. lesabre gauge cluster
  56. '96 lesabre no start, no dash warn lts
  57. 92 Lesabre won't start hot
  58. 89 lesabre
  59. 92 buick
  60. Lady needs help w/1997 LeSabre Limited
  61. 93 TPS and tranny problems
  62. 1986 Buick LeSabre Custom weak spark
  63. 00 Le. speed,tach,odo,turn signals no work
  64. do we need adifferential oil change on lesabre 97
  65. 1992 LaSabre Electrical problems
  66. 1992 LeSabre Dash removal procedures
  67. 92 LeSabre ALDL
  68. 1997 Lesabre Transmission
  69. 94 LeSabre - Shudder upon take-off
  70. 97 le sabre no turnover
  71. Aftermarket Tach
  72. 92 Lesabre Shuts Off
  73. strut reccomendations
  74. Cigarette lighter
  75. Won't Start
  76. WET Back floor mats?
  77. 90 Lesabre Blower motor staying on when key is off
  78. 92 LeSabre no HVAC Blower
  79. 94 lesabre fuel pump relay location - please help
  80. Massive OIL Leak
  81. PVC valve
  82. Passing gear won't engage!
  83. replacing starter in 1995 LeSabre
  84. ac blowing wierd
  85. cruise control
  86. Help with 2000 LeSabre automatic headlights
  87. Recharging AC in 94 lesabre; HELP!
  88. The LeSabre's REPLACEMENT : Buick "Lucerne"
  89. check engine light
  90. 92 LeSabre Misfires/hesitates only when hot
  91. 1989 buick lesabre LTD driver door jammed
  92. How can I manually jumpstart A/C compressor bypassing the pressure sensor?
  93. Does This LeSabre look like a good deal?
  94. Replacing ECU/ECM
  95. Catalytic Converter Warranty question..
  96. 1994 LeSabre Temperature Cooling Sensor Location???
  97. Spare Tire
  98. LeSabre
  99. Question on 3800 series engine
  100. 2000 LeSabre Dashboard change
  101. Computer needeed
  102. 89
  103. 1986 Lasabre
  104. 1998 Lesabre Fuel Line Leaks
  105. 95 LeSabre 3800 problem.... help?
  106. Wheel bearings
  107. 97 Trunk Leak
  108. High INTAKE AIR TEMP
  109. abs light
  110. * Speedometer Help!!! *
  111. ac compressor
  112. Replacing crank sensor on 92 Lesabre
  113. Air Bag Light
  114. Taillight Cover Assembly
  115. brake light on 82 LeSabre
  116. 1986 buick LeSabre Custom no spark on #1 #3#4 #6 and spark on #2 #5 is good
  117. trans fluid/filter change
  118. Help with car engine problem....
  119. 1994 Rear View Mirror Replacement
  120. '00 Headers
  121. top speed in 89'
  122. 91 LeSabre Fuel Problem
  123. 94 Buick won't start--again!, etc.
  124. 1991 Buick LeSabre with 3800 Motor
  125. New Starter Still won't start
  126. A/C Goes in and out on my 92
  127. '92 lesabre electrical problems
  128. Leaking Fluid From Muffler
  129. fuel presure regulator on 94 buick lesabre!
  130. Metal clanking sound coming from tranny-flywheel/plate during startup and shutdown.
  131. Location of Fuse Panel for a 88 buick lesabre?
  132. Blocking/Removing EGR
  133. Anyone replaced a exhaust manifold gasket?
  134. vibration from front end while braking
  135. Sulfur Smell-89 Le Sabre
  136. 92 lesabre no power to a/c
  137. Speedo Cluster Swap
  138. 94 Lesabre Front/Rear Struts Help
  139. 1996 Buick Lesabre Wont Start
  140. Headlight Woes
  141. Transmission Solenoids
  142. 92 LeSabre won't start when hot...
  143. the a/c blues
  144. Back Windows - Any lower?
  145. Cold Air One Side - Hot Air the Other!
  146. Frozen Wheel Nut
  147. HELP a/c problem
  148. air conditioning
  149. Where online, is best place to buy parts?
  150. security system le sabre 1992
  151. No oil pressure 93 Lasebre
  152. fuel gauge
  153. harmonic balancer 92 buick lesabre
  154. changing water pump
  155. 95 Lesabre 3800 engine problem
  156. Mitchell OnDemand 5 DVD
  157. 94 Le Sabre Tranny Problem
  158. 1995 LeSabre Custom trouble starting
  159. 94 Lesabre Tranny problem
  160. Wants to stall during cold start-up
  161. Paint
  162. Motor Mounts
  163. '89 LeSabre Speakers
  164. 2 separate problems with my 92 lesabre
  165. 3800 serpentine belt
  166. buick TPS problems
  167. need upholstery
  168. spark plugs
  169. 94 LeSabre Air Conditioning could be dying
  170. 1995 air conditioning problem
  171. old car
  172. 95 Lesabre Custom won't start
  173. TPS - Hesitation problem - 1994 Lesabre Buick
  174. New Owner... Big Plans !!!
  175. Speaker Sizes?
  176. Meineke broke my air vent damper
  177. 95 LeSabre Randomly Stalls
  178. headlights
  179. Lesabre's Transmission High Gear Doesn't Shift
  180. Transmission High Gear Does's Shif.
  181. i need help
  182. 2000 LeSabre Platinum
  183. headlights turn on by themselves
  184. Squeak/ squeal
  185. roof falling off - '89 lesabre.
  186. Spark Plugs
  187. 1985 buick lesabre collector edition door adjustment
  188. Problem with my 92 LeSabre dying
  189. Lights Stay On - '92
  190. Fuel tank Installation "HELP"
  191. Lights flicker on '02
  192. intake manifold leak, possible lifter noise too
  193. 1996 door latch assembly
  194. Is it possible to replace a tranny from a 1989 Lesabre with a 1992 Lesabre?
  195. Changiing Fluids
  196. Changiing Fluids
  197. 1987 Water Pump
  198. Help!! 92 Buick Lesabre Engine Is Running Rough
  199. 1999 Lesabre trouble starting
  200. 5W-30 in a Lesabre?
  201. 90 climate control prob
  202. ATTN: 1995+ LeSabre Owners with 3800 (L36 MOTOR PLASTIC INTAKE)
  203. 97 Buick La Saber - HELP ME !!!!!!
  204. Replacing radio in '94 Buick LeSabre Cusom
  205. replacing wipers on 90 lesabre
  206. 92 lesabre custom
  207. 92 Buick LeSabre resonator
  208. Injectors, no pulse on any of them
  209. Miles on the car...........
  210. LeSabre does not start
  211. LeSabre doesn't start
  212. Misfiring, now not starting, 94 LeSabre
  213. Misfiring, now not starting
  214. Dashboard Gear switcher
  215. Anyone know about throttle position sensors
  216. Radiator fan won't run?
  217. stiffen up ride
  218. Upgrade to automatic climate control - 2001 LeSabre
  219. 92 LeSabre K&N kit???
  220. 94 Buick LeSabre misfires
  221. 94 LeSabre with intermittent starting issue
  222. 1991 LeSabre Stalling In Traffic
  223. 89 3.8 runs for only a few seconds
  224. Another Window Problem
  225. tranny not shifting well.
  226. E-brake cable on 90 LeSabre
  227. 1999 rear struts
  228. 93 to 94 transmission swap?
  229. 1986 buick lasabre stalling
  230. Auto dimming mirrors
  231. 00 Lesabre - rattling sound - rt front
  232. Normal tire pressure
  233. 90 Lesabre won't start when warm
  234. 92 buick
  235. Fuel efficiency on '01
  236. Lesabre '01 brake noise
  237. 1992 lesabre
  238. cruise control not turning on
  239. '89 Le Sabre -Sealant for Small Oil Leak?
  240. Radio shuts off, heater shuts off,
  241. 92 Buick Lesabre Custom 3.8 just shuts off
  242. Air Bag Question
  243. 1989 fuel tank vent prob
  244. 92 lesabre
  245. 85 lesabre dies when going into drive
  246. Type of Scanner to use on 95 LeSabre
  247. Disconnecting rain sensors on wipers???
  248. Replace cam sensor and magnet on a '92 (3800)
  249. Detonation?
  250. 1993 lesabre spudders loses acceleration and stalls when less than a half tank of gas
