View Full Version : LeSabre
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19
  1. 94 LeSabre randomly stalling..PLEASE HELP!
  2. 2005 LeSabre ABS computer
  3. 1997 LeSabre Frozen Wipers
  4. Horn keeps going off by itself on my '94 Lesabre?
  5. Sputter
  6. 95 lesabre tranny cooler lines
  7. 98 LeSabre, How Can I Disable Daytime Running Lights and Twilight Sentinel
  8. replacing stop lamps
  9. 93 Buick LeSabre "starving for gas"?
  10. Oil pressure sender location
  11. Fuel Pump fuse keeps blowing?
  12. Can someone explane what/why I need to replace a TPS on a 97
  13. Lug Pattern
  14. Alternator replaced and now car won't start
  15. Terrible Mpg and Fuel Gauge Moving Side To SIde
  16. Transmissions swaps.
  17. Tranney slip
  18. 93 le sabre heater problems
  19. Emergency Brake?
  20. speedo and turn signals
  21. 93 Lesabre C Charging Prob.
  22. 5.0 LeSabre Estate Wagon
  23. Front End Vibration
  24. Auxiliary Input for OEM Radio
  25. Heated Seat Element Replacement
  26. Re: 98 LeSabre Series II - Plastic Plenum
  27. Replacing TCC Solenoid
  28. 93 Lesabre Pinhole leak in tranny cooler line
  29. Rough Idle
  30. 97 LeSabre coolant disappearance
  31. Re: Fuel in oil! Why?
  32. Annoying horn problem
  33. 3800 Manifold Swap (L27 to LN3)
  34. 1997 lesabre intake manifold repair kit
  35. Is This The Transmission Modulator?
  36. 92 - won't start at all
  37. Radiator Problem
  38. A/C Problem
  39. Rear Struts/Springs vs Quick Struts
  40. Pressure Control Solenoid
  41. headlight adjustment??
  42. 1992 90k 3800 running bad - coils?
  43. Lights in steering wheel out
  44. How to remove engine cover
  45. Experts Needed For Phantom Problem
  46. Where is the flasher?
  47. front right lower control arm ball joint replacement?
  48. 90 Le Sabre heater problem-help!!
  49. A/C Heater Not Working. Could This be The Problem
  50. Evaporator Canister...?
  51. HELP! I need a little guidance
  52. Mechanic stumped
  53. Air Temperature Sensor
  54. 92 rear seat belt
  55. Right side half-shaft axle on '90 Lesabre
  56. Speedometer Slightly Off?
  57. Re: changing the plentum - Bnaylor?
  58. 97 LeSabre Headlight Installation help needed
  59. Cold Start
  60. Ball-joint replacement
  61. Looking for A/C Fuse & Relay Box
  62. 98 w/81k miles
  63. Help Lesabre Will Not Fire!
  64. 98 lasabre water pump bolt
  65. Re: Cam sensor code
  66. Electric questions
  67. LeSabre - turn signal problem
  68. 94 lasabre windown
  69. 94 lasabre trunk problems
  70. 94 Lesabre Battery!
  71. Front end
  72. 89 Lesabre, long start, popping at hwy speed
  73. 94 lesabre alternator
  74. parking lights simple question
  75. Leveling System
  76. Antenna and Radio problems
  77. rim size
  78. Help Reprogramming Remote-2000 Buick LeSabre
  79. 94 buick lesabre-brake pedal goes way down-left front/right rear wheels only braking
  80. 93 LeSabre Flasher
  81. 1994 Lesabre Trouble Codes 321 and 361
  82. Trouble codes for 1995 Lesabre
  83. 92 Buick Lesabre
  84. 95 Lesabre A/C Heater Problem
  85. 1992 lesabre batter going dead
  86. 95 lesabre no start
  87. 91 Buick Steering Wheel wobling
  88. 93 Buick won't go into gear!!!
  89. 95 Lesabre vibration. At wits end!
  90. gas cap loose
  91. 93 lesabre front end problems
  92. 92, Blower motor intermidiatly off and on
  93. 97 buick lesabre cluster
  94. supercharger
  95. 1993 Lesabre, Occasional Tranny locking
  96. 97 Lesabre gas
  97. 2001 LaSabre - Odd Temperature Issue
  98. Headliner size difference b/w 2dr and 4dr
  99. 98 rear shock removal?
  100. Door catch problem
  101. Opinions on a '93, please!
  102. 92 lesabre dies at light
  103. P1406 code fixed
  104. ignition relay
  105. 97 Lesabre Gas Line Tank to Fuel Filter
  106. '93 Le Sabre Vacuum Hose Issues
  107. Tranny Service
  108. instrument cluster upgrade?
  109. LeSabre brake issues
  110. Tranmission Gone Nutty
  111. 1993 Lesabre heating problems
  112. Switching the Color of the Dash
  113. HELP!! 1997 LeSabre Squealing Squeaking Noise Drives Me Crazy
  114. Delco Alternator--MK 2
  115. 2001 Buick LeSabre - Headllight relay prob??
  116. '97 Lesabre
  117. Broken starter housing...
  118. serious battery drain
  119. LeSabre--The Granny Problem
  120. 92 Lesabre AC/Heat won't blow?
  121. 98 lasabre water pump
  122. Mass Airflow Sensor
  123. 93 won't start at all
  124. What is the O.E. tire size for 1994 LeSabre?
  125. starting problems 1997 Lesabre
  126. GM Stock Cars--Ballad of the Ghetto Rides
  127. Rear seats, and speakers...
  128. Brake Indicator Light Beeps When Accelerating
  129. Removal 2000 Lesabra Steering Wheel Buttons
  130. overdrive
  131. Is Resistance Futile?
  132. 95 lesabre leaking oil??
  133. 2000 LeSabre Brakes
  134. Dual Climate Control - No heat passenger dash
  135. 88 LeSabre - Replacing Flasher Unit
  136. 2000 LeSabre, whine when turning
  137. '92 LeSabre DEADLY BRAKES!
  138. Engine Stalls - LeSabre93 Custom
  139. Buick LeSabre will not start, mechanics stumped
  140. 86 3.8 Le Sabre Won't Crank, Start.
  141. no start, wiggle key , START!!!
  142. What Brand of O2 Sensor Do You Use?
  143. Dash pad removal? 00 Lesabre
  144. Mysteries of the 92 LeSabre
  145. 97 Lesabre power steering fluid leak
  146. RPM "flare" when tranny shifts into OD...
  147. Code P1361 Returned and Completely Cuts Out on Bumpy Roads
  148. Possible Remote Trunk?
  149. 93 Lesabre Thermostat - Temp Gauge
  150. Power steering problem?
  151. Thermostat For '97 Lesabre
  152. 92 LeSabre kills while driving
  153. lesabre Limited 97 A/C problem
  154. Traction Off??..
  155. Wont Start!!
  156. Air exchange door location
  157. 90 Buick LeSabre shudder@35-40MPH
  158. Need help unclogging drain holes
  159. 92 lesabre tranny maintenence question
  160. 1994 buick lesarbe blower motor
  161. 94 Lesabre Engine/Trans problem???
  162. 1995 Lesabre motor surging and dying at stops
  163. '94 LeSabre Stalling, other bizarre issues
  164. 1992 LeSabre Trouble Code 13 & 44
  165. 94 Lesabre Alignment
  166. Car Keeps Cutting Off
  167. Can ecm be checked?
  168. changing rear struts on 87 lesabre
  169. 94 LeSabre Scanned!
  170. 94 LeSabre Headaches!
  171. Electric Supercharger
  172. 1994 Buick LeSabre Limited...
  173. Bad mileage... bad, bad mileage
  174. HID Xenon Kits.. aww shnaps!
  175. How do I check ignition coils??
  176. No heat on passenger side 95 lesabre
  177. 92 Le Saber - blower motor??
  178. Very odd tank fill-up problem
  179. need help with 92 lesabre
  180. 93 Lesabre Glove Box Door Key Cylinder R/R
  181. 1988 Buick LeSabre - Replacing heater core
  182. 1993 Buick Lesabre Keyless entry programming
  183. Scan tools for newbie ?
  184. 95 Lesabre intermitint OD problem
  185. Some More 94 lesabre problems
  186. 94 Buick Lesabre Problems!
  187. high flow catalytic converter..?
  188. 94 lesabre park lamps
  189. 92 Buick Le Sabre Limited FSM
  190. 97 lesabre Check engine light on
  191. How to get the brake booster out?
  192. engine light always on
  193. 94 Lesabre with battery warning light
  194. 87 lesabre rack and pinion question
  195. Maf or TPs?
  196. park avenue horns?
  197. Stall during turns
  198. 1992 LeSabre RKE
  199. brake lines
  200. Because theres no one who visits VW
  201. Bleeding brakes - 1994 LeSabre - proper sequence?
  202. New aftermarket headunit
  203. 1990buick lesabre electrical problem
  204. Torque spec for 94 Lesabre brake caliper?
  205. 1995 LeSabre Water Pump Seized!!!
  206. Turbonator!
  207. 1990 LeSabre starter issues
  208. 92 LeSabre Location of ECM Module?
  209. buzzing noise
  210. Help ME!!!
  211. New and Old Members Please Read
  212. Horn problem
  213. Backfiring 93 Lesabre
  214. Some fairly extensive brake work
  215. OBD 1 code format for 94 Lesabre v6 3.8L
  216. 01 locks me out
  217. 2000 Lesabre - Radiator Petcock & Eng Block Drain ??
  218. Horn
  219. Bad stumble under load
  220. 1990 LeSabre.....Any advice is apprieciated;)
  221. Keyless Remote
  222. Used muffler ok?
  223. 1995 LeSabre Custom problem with wet conditions..
  224. 95 Lesabre Pass Key Problem
  225. 91 Buick LeSabre Transmission
  226. Noisy A/C Compressor Clutch
  227. Alarm keeps going off
  228. Air bag light on?
  229. fastest way to go 0-60
  230. 1994 Buick Lesabre - Headlight Issues
  231. 1999 LeSabre
  232. '01 LeSabre - McPherson Struts
  233. 95 LeSabre ABS problem
  234. Rear driver side tire wont move??
  235. A/C Vacum.
  236. 94 LeSabre starting problem
  237. 1995 Le Sabre trunk remote and dash release won't work
  238. 2002 LeSabre Air Conditioning Problem
  239. No Panel Vents
  240. Passkey Help
  241. Check Engine Light 1997 LeSabre
  242. 95 LeSabre not starting randomly
  243. Series 1 cold air intake
  244. Vacume leak that I can only hear when ac is on....
  245. Hubcap Question
  246. SparkPlugs - Series II Help! :-)
  247. '01 Lesabre transmission problems
  248. '01 Lesabre rear window motor
  249. '93 LeSabre Blinker trouble
  250. '93 LeSabre Silly Windows
