View Full Version : Legend/RL
Pages : [1] 2
  1. What is the "Cash for Clunkers" Program going to do to our spare parts
  2. 91 acura legend transmition issue
  3. Rack and Pinion Sterring BOOT
  4. 91 acura legend
  5. Shuttering around 1500 rpms
  6. 97 Acura RL Buzzing noise on Start Up?
  7. Sticking Thermostat?
  8. Need Help
  9. Need help finding rswift or parts
  10. HELP.HELP.2000 rl remote
  11. Tranny fluid for 95 Legend
  12. 88 legend a/c help
  13. '91 Legend Speedometer works on and off! Answers?
  14. discount code for delray acura newsletter
  15. problem
  16. 1992 Acura Legend power seat removal problem
  17. Changing drive belts on 95 acura legend help
  18. 92 Acura Legend Brake Problem
  19. 1987 legend transmission problem
  20. help!!!!!!!!!! car turns off while driving!
  21. Acura Legend Performance?
  22. Why is my ABS light on?
  23. 91 legendary legend overheating
  24. 87 legend code help
  25. 93 Legend Various Issues
  26. 92 Acura Legend Tranny change
  27. 91 legend overheating
  28. Turn Signals.
  29. Seafoam gone wrong?
  30. 93 legend weird electrical problems
  31. 1989 Legend Coupe Steering Column Tilt Broken
  32. how do you take of 93 legend console
  33. Dead Legend Need Help Asap!!!!!
  34. shaking
  35. horn
  36. How High Can I Go?
  37. transmission hard shifts
  38. Help!! ABS and TCS lights are on.
  39. Tranny Fluid
  40. what can be done to this engine
  41. Fuel Tank size 5% over
  42. Acura RL 2003 keyless remote
  43. 88 legend automatic question
  44. c27a to c32,c30,c35,or g/j series swap?
  45. steering wheel
  46. need the diagram for distributor on a 88 acura legend
  47. Legend won't start-battery dies
  48. 1990 legend 3.2L engine swap
  49. Relay
  50. OIL LEAK HELP !!! 89 Acura Legend
  51. 98 Acura Rl Speedometer Not Working
  52. 92 parts for 93 Legend
  53. one year any better than the others 91-95?
  54. 91 hood does not latch on 95 legend
  55. 88 Legend gear problems
  56. 93 Legend Timing Belt/Water Pump
  57. '92 Legend - How to remove metal door edge damaged by thief?
  58. 89 legend 5 speed ?
  59. WTB 93+ legend
  60. acura legend 95 gs problem
  61. 88 legend timing marks
  62. random crank but no start prob 89 legend
  63. dash lights replacement
  64. Engine ticking sound
  65. master brake cylinder replacement
  66. Thinking about buying a legend
  67. Speedometer Problem 2000 RL
  68. 93 legend blower motor replacement
  69. Need Help, Please!!!!!!!
  70. Hello, I am new here - just wanted to say what's up
  71. '91 Legend LS Coupe - What's this "keyhole" for?
  72. 89' Legend Suspension Question
  73. Timing belt keeps trying to slip off??????
  74. 89 Legend Cylinders
  75. 91 legend causing headaches on start!!help
  76. 89 Legend L for sale (BRO, tranny bad, etc)
  77. 99 RL: no sound from RL
  78. 1990 legend please help
  79. 1/4 time
  80. '89 Idle Slow/Stop and Check Engine Light On
  81. Lights for 92 Acura Legend
  82. steering problems
  83. 1994 Legend wiper issue
  84. Moonroof off-track
  85. 1990 Legend rear calipers
  86. High RPM chattering..
  87. legend for parts!
  88. 96 Acura RL Radio R&R
  89. 88' Acura Legend that won't start.
  90. no sound on cd player but radio work fine
  91. 91 legend 5spd no start period.
  92. Frame repair......Need help
  93. problem cranking when cold
  94. problem cranking when cold
  95. Fender Bo Bender
  96. Looking for a 6spd legend
  97. 90 Legend LS...Clutch Out!! Do I Need Special Tool?
  98. Acura & Honda Main Relay Fix,Ignition System & Switch,Overheating,VSS
  99. Throttle Body and Throttle Position Sensor
  100. HELP 89 legend problem!
  101. radio Codes for Legend factory radio
  102. c32a engine performance
  103. 96 RL axle splines
  104. 90 Legend Oil leak
  105. blowing warm air
  106. suggestions for a sound system upgrade
  107. 93 legend overheated, now wont start
  108. Surging at idle on '94 Legend?
  109. legend coupe 6 speed 4sale
  110. trunk lock
  111. 3.2/3.5 motor pics?
  112. 2G Legend sore spots
  113. high miles
  114. Carb
  115. diagnostic connector 95 legend 3.2
  116. Clutch Sinks to Floor and Does not Return
  117. 1987 Acura Legend...
  118. 88 lengend rear brake problem
  119. 92 acura legend overheated
  120. Battery light
  121. Throttle Angle Sensor
  122. '88 acura legend won't start sometimes
  123. Cruise Control
  124. F/S 89 Acura Legend Coupe in Toronto
  125. '88 Legend L maintenance & service question
  126. Help! 1988 legend starter
  127. FS- 91 Legend , great parts car !!
  128. Running condenser fan
  129. What could cause a code 9 on 88 legend?
  130. 1990 Legend....Starting Issues
  131. 88 legend performance headers?
  132. 1990 Acura won't start when hot or in the sun
  133. smoking alternator!!!
  134. 93 Acura anti-theft malfunction
  135. Question about heater?
  136. 2005 RL Battery dies
  137. Looking to buy 94 Legend, 120,000-$6800
  138. Sluggish cranking - especially when cold
  139. 88 Legend stalls when I put the clutch in.
  140. honda legend heat sensor code and s4 light
  141. FS: Legend Coupe 1992
  142. Did 5 cylinder legand ever happen?
  143. Leather, Pleather or Vinyl?
  144. Clutch Will Not Engage
  145. Circulating Blower not working
  146. 97 RL Ride quality
  147. For Sale-- 93 Legend $1650--clean-runs/drives
  148. Intermittent heating up at idle '89 Legend
  149. d4 light flashes
  150. if you want anything from a 1988 legend tell me now
  151. Seat swap question
  152. Question
  153. 93 Legend Replace Bose radio with regular Acura radio
  154. Why Won't It start??! 87 Legend
  155. 88 legend. should i buy it ?
  156. Impossiable 91 Legend Brake problem?
  157. Proud owner of a 93 Legend
  158. headlight problems
  159. 1989 Acura Legend Shifting Problems/ Automatic
  160. RL ABS Code access
  161. 1997 Acura RL shutter
  162. 1988 acura legend wet carpet problem
  163. Anyone here from Acura-Legend.com
  164. Distributor problems, code a code 8
  165. 1990 Legend, need information
  166. Help!!! Ignition Key Cylinder
  167. Ignition problem
  168. late 80's engine swap
  169. removing ignition lock cylinder
  170. FS: G1 JDM Honda Legend Clear Corners
  171. parting out 87 legend
  172. Can I install these myself? CVC & Freq Valve
  173. 91 Legend 2dr/Brake lights
  174. "Brake Lamp"?
  175. non-dealer repair option - Silicon Valley
  176. 92 Legend - ABS lite stuck on, won't pass inspection
  177. 87 Acura Legend Wont Start
  178. 1990 Legend Transmission problems
  179. Acura legend question
  180. 96 rl steering/handling
  181. 1996 RL broken outside door handle
  182. 93 acura legend, help please!!!!
  183. HELP!! 92 legend auto tranny problem/noise
  184. 1991 Heater Not Working
  185. 88-91 V6 5 speed transmission ( full swap needed )
  186. 88 with eltrical problems
  187. Legend 92 - E Brake Light Stays on! ABS Kicks in! (unwantingly)
  188. 87 legend sedan shift problems tranny ?
  189. FORUM RULES AND GUIDELINES - MUST READ!!!
  190. where's the fuse....?
  191. Looking to buy Legend Coupe
  192. selling 94 Legend
  193. 1988 Acura Legend (anti lock light)
  194. 87 acura legend v-6 Feul problem????
  195. 88 legend getting fuel and spark, won't start
  196. Egr Valve
  197. suspension question
  198. 88 Legend Stumbles on Acceleration
  199. legend speedometer
  200. 2005 Acura RL Coupé
  201. 86 Legend Will Not Crank...HELP !!!
  202. 1991 acura l
  203. headlight replacement
  204. Seat Removal
  205. 1991 new steel acura legend hoods
  206. How do you make a LEgend Manual
  207. 88 Legend Sunroof Leak
  208. 92 Legend Alarm problem
  209. how do i tell my headgasket need to be replaced?
  210. Problem with HVAC. Legend wiring diagrams?
  211. left rear window regulator
  212. 92 manual legend - looking for spark plug wires
  213. Electrical Problems
  214. windshield flogged up
  215. WTB:16" stock gs wheels.
  216. 89 leged transmission swap ?'s
  217. Legend hood
  218. Anyone Got 3.5 Engine Parts?
  219. This forum is....
  220. Brake and Anti Lock lights
  221. dead legend ?
  222. Couple questions
  223. 90 acura legend transmission for sale
  224. help reprogramming remote
  225. 89 Legend will not idle while running
  226. O2 sensors.. i get varied opinions from mechanics
  227. Acura
  228. Help me find fuel pump relay for 87 legend
  229. Update: Condenser Fan - Elec
  230. rl starting problems
  231. Disappointed with posts
  232. Best shocks?
  233. Condenser Fan - Elec
  234. corner lights and bumper
  235. '88 Legend starter
  236. engine swap
  237. Question about a '90 Legend Coupe Window Regulator
  238. 1990 acura won't start on hot days or when left under the sun.
  239. Is it any good?
  240. tranny swap
  241. Acura Legend sedan and coupe Pics.......
  242. Lexus or a legend which should I buy?
  243. Radio code
  244. Acura Legend 90 sedan kill or let live?
  245. 1990 Acura Legend Ls 2 Door
  246. 1990 Acura Legend Ls 2 dr Body Kit??
  247. Drivetypes?
  248. 1988 acura legend issues
  249. '88 Legend-New to AF-:Tranny problem
  250. acura legend coupe inner fender shields
