View Full Version : Legend | RL
- sinking money into a losing battle it seems....
- ???? 92 legend buying questions ???
- 92 Legend problems
- Electrical problems now
- radio code
- 94 legend transfer case
- 1991 Legend LS AC Belt
- Consider selling my 1988 Acura Legend
- Non-Operative Fuel Gauge
- 2000 Acura RL Power driver seat problem
- What is the "Cash for Clunkers" Program going to do to our spare parts
- 91 acura legend transmition issue
- Rack and Pinion Sterring BOOT
- 91 acura legend
- Shuttering around 1500 rpms
- 97 Acura RL Buzzing noise on Start Up?
- Sticking Thermostat?
- Need Help
- Need help finding rswift or parts
- HELP.HELP.2000 rl remote
- Tranny fluid for 95 Legend
- 88 legend a/c help
- '91 Legend Speedometer works on and off! Answers?
- discount code for delray acura newsletter
- problem
- 1992 Acura Legend power seat removal problem
- Changing drive belts on 95 acura legend help
- 92 Acura Legend Brake Problem
- 1987 legend transmission problem
- help!!!!!!!!!! car turns off while driving!
- Acura Legend Performance?
- Why is my ABS light on?
- 91 legendary legend overheating
- 87 legend code help
- 93 Legend Various Issues
- 92 Acura Legend Tranny change
- 91 legend overheating
- Turn Signals.
- Seafoam gone wrong?
- 93 legend weird electrical problems
- 1989 Legend Coupe Steering Column Tilt Broken
- how do you take of 93 legend console
- Dead Legend Need Help Asap!!!!!
- shaking
- horn
- How High Can I Go?
- transmission hard shifts
- Help!! ABS and TCS lights are on.
- Tranny Fluid
- what can be done to this engine
- Fuel Tank size 5% over
- Acura RL 2003 keyless remote
- 88 legend automatic question
- c27a to c32,c30,c35,or g/j series swap?
- steering wheel
- need the diagram for distributor on a 88 acura legend
- Legend won't start-battery dies
- 1990 legend 3.2L engine swap
- Relay
- OIL LEAK HELP !!! 89 Acura Legend
- 98 Acura Rl Speedometer Not Working
- 92 parts for 93 Legend
- one year any better than the others 91-95?
- 91 hood does not latch on 95 legend
- 88 Legend gear problems
- 93 Legend Timing Belt/Water Pump
- '92 Legend - How to remove metal door edge damaged by thief?
- 89 legend 5 speed ?
- WTB 93+ legend
- acura legend 95 gs problem
- 88 legend timing marks
- random crank but no start prob 89 legend
- dash lights replacement
- Engine ticking sound
- master brake cylinder replacement
- Thinking about buying a legend
- Speedometer Problem 2000 RL
- 93 legend blower motor replacement
- Need Help, Please!!!!!!!
- Hello, I am new here - just wanted to say what's up
- '91 Legend LS Coupe - What's this "keyhole" for?
- 89' Legend Suspension Question
- Timing belt keeps trying to slip off??????
- 89 Legend Cylinders
- 91 legend causing headaches on start!!help
- 89 Legend L for sale (BRO, tranny bad, etc)
- 99 RL: no sound from RL
- 1990 legend please help
- 1/4 time
- '89 Idle Slow/Stop and Check Engine Light On
- Lights for 92 Acura Legend
- steering problems
- 1994 Legend wiper issue
- Moonroof off-track
- 1990 Legend rear calipers
- High RPM chattering..
- legend for parts!
- 96 Acura RL Radio R&R
- 88' Acura Legend that won't start.
- no sound on cd player but radio work fine
- 91 legend 5spd no start period.
- Frame repair......Need help
- problem cranking when cold
- Fender Bo Bender
- Looking for a 6spd legend
- 90 Legend LS...Clutch Out!! Do I Need Special Tool?
- Acura & Honda Main Relay Fix,Ignition System & Switch,Overheating,VSS
- Throttle Body and Throttle Position Sensor
- HELP 89 legend problem!
- radio Codes for Legend factory radio
- c32a engine performance
- 96 RL axle splines
- 90 Legend Oil leak
- blowing warm air
- suggestions for a sound system upgrade
- 93 legend overheated, now wont start
- Surging at idle on '94 Legend?
- legend coupe 6 speed 4sale
- trunk lock
- 3.2/3.5 motor pics?
- 2G Legend sore spots
- high miles
- Carb
- diagnostic connector 95 legend 3.2
- Clutch Sinks to Floor and Does not Return
- 1987 Acura Legend...
- 88 lengend rear brake problem
- 92 acura legend overheated
- Battery light
- Throttle Angle Sensor
- '88 acura legend won't start sometimes
- Cruise Control
- F/S 89 Acura Legend Coupe in Toronto
- '88 Legend L maintenance & service question
- Help! 1988 legend starter
- FS- 91 Legend , great parts car !!
- Running condenser fan
- What could cause a code 9 on 88 legend?
- 1990 Legend....Starting Issues
- 88 legend performance headers?
- 1990 Acura won't start when hot or in the sun
- smoking alternator!!!
- 93 Acura anti-theft malfunction
- Question about heater?
- 2005 RL Battery dies
- Looking to buy 94 Legend, 120,000-$6800
- Sluggish cranking - especially when cold
- 88 Legend stalls when I put the clutch in.
- honda legend heat sensor code and s4 light
- FS: Legend Coupe 1992
- Did 5 cylinder legand ever happen?
- Leather, Pleather or Vinyl?
- Clutch Will Not Engage
- Circulating Blower not working
- 97 RL Ride quality
- For Sale-- 93 Legend $1650--clean-runs/drives
- Intermittent heating up at idle '89 Legend
- d4 light flashes
- if you want anything from a 1988 legend tell me now
- Seat swap question
- Question
- 93 Legend Replace Bose radio with regular Acura radio
- Why Won't It start??! 87 Legend
- 88 legend. should i buy it ?
- Impossiable 91 Legend Brake problem?
- Proud owner of a 93 Legend
- headlight problems
- 1989 Acura Legend Shifting Problems/ Automatic
- RL ABS Code access
- 1997 Acura RL shutter
- 1988 acura legend wet carpet problem
- Anyone here from Acura-Legend.com
- Distributor problems, code a code 8
- 1990 Legend, need information
- Help!!! Ignition Key Cylinder
- Ignition problem
- late 80's engine swap
- removing ignition lock cylinder
- FS: G1 JDM Honda Legend Clear Corners
- parting out 87 legend
- Can I install these myself? CVC & Freq Valve
- 91 Legend 2dr/Brake lights
- "Brake Lamp"?
- non-dealer repair option - Silicon Valley
- 92 Legend - ABS lite stuck on, won't pass inspection
- 87 Acura Legend Wont Start
- 1990 Legend Transmission problems
- Acura legend question
- 96 rl steering/handling
- 1996 RL broken outside door handle
- 93 acura legend, help please!!!!
- HELP!! 92 legend auto tranny problem/noise
- 1991 Heater Not Working
- 88-91 V6 5 speed transmission ( full swap needed )
- 88 with eltrical problems
- Legend 92 - E Brake Light Stays on! ABS Kicks in! (unwantingly)
- 87 legend sedan shift problems tranny ?
- FORUM RULES AND GUIDELINES - MUST READ!!!
- where's the fuse....?
- Looking to buy Legend Coupe
- selling 94 Legend
- 1988 Acura Legend (anti lock light)
- 87 acura legend v-6 Feul problem????
- 88 legend getting fuel and spark, won't start
- Egr Valve
- suspension question
- 88 Legend Stumbles on Acceleration
- legend speedometer
- 2005 Acura RL Coupé
- 86 Legend Will Not Crank...HELP !!!
- 1991 acura l
- headlight replacement
- Seat Removal
- 1991 new steel acura legend hoods
- How do you make a LEgend Manual
- 88 Legend Sunroof Leak
- 92 Legend Alarm problem
- how do i tell my headgasket need to be replaced?
- Problem with HVAC. Legend wiring diagrams?
- left rear window regulator
- 92 manual legend - looking for spark plug wires
- Electrical Problems
- windshield flogged up
- WTB:16" stock gs wheels.
- 89 leged transmission swap ?'s
- Legend hood
- Anyone Got 3.5 Engine Parts?
- This forum is....
- Brake and Anti Lock lights
- dead legend ?
- Couple questions
- 90 acura legend transmission for sale
- help reprogramming remote
- 89 Legend will not idle while running
- O2 sensors.. i get varied opinions from mechanics
- Acura
- Help me find fuel pump relay for 87 legend
- Update: Condenser Fan - Elec
- rl starting problems
- Disappointed with posts
- Best shocks?
- Condenser Fan - Elec
- corner lights and bumper
- '88 Legend starter
- engine swap
- Question about a '90 Legend Coupe Window Regulator
- 1990 acura won't start on hot days or when left under the sun.
- Is it any good?
- tranny swap
Automotive Network, Inc., Copyright ©2012
